Autor Tópico: Electronics Demonstrations - Circuit Simulator Applet  (Lida 3994 vezes)
Offline mauricio
    • http://www.dvpt.com
« em: 30 de Julho de 2010, 16:30 »
Um Simulador Muuuuuito bom! http://www.falstad.com/circuit/e-index.html
É possivel manipular valores  e exportar os resultados, pode ser consultado online ou fazer o download do Applet em Java Completo.
Em anexo o Java Applet Completo para download. (651K)
Divirtam-se  :)
The demonstrations use a java applet that simulates electronic circuits.
Vejam só a quantidade de simulações:
    * Basics
          o Ohm's Law
          o Resistors
          o Capacitor
          o Inductor
          o RLC Circuit
          o Voltage Divider
          o Series/Parallel
                + Inductors in Series
                + Inductors in Parallel
                + Capacitors in Series
                + Capacitors in Parallel
          o Thevenin's Theorem
          o Norton's Theorem
    * A/C Circuits
          o A/C Response of Capacitor
          o A/C Response of Inductor
          o Caps of Various Capacitances
          o Caps w/ Various Frequencies
          o Inductors of Various Inductances
          o Inductors w/ Various Frequencies
          o Impedances of Same Magnitude
          o Series Resonance
          o Parallel Resonance
    * Passive Filters
          o High-Pass Filter (RC)
          o High-Pass Filter response (RC)
          o Low-Pass Filter (RC)
          o High-Pass Filter (RL)
          o Low-Pass Filter (RL)
          o Band-Pass Filter
          o Notch Filter
          o Twin-T Filter
          o Crossover
    * Other Passive Circuits
          o 3-Way Light Switches
          o 3- and 4-Way Light Switches
          o Differentiator
          o Wheatstone Bridge
          o Critically Damped RLC
          o Current Source
          o Transformers
                + Transformer
                + Step-Up Transformer
                + Step-Down Transformer
                + Long Distance Power Transmission
                + Transformer w/ DC
          o Inductive Kickback
          o Blocking Inductive Kickback
          o Power Factor
          o Power Factor Correction
          o LC Ladder
          o Phase-Sequence Network
    * Diodes
          o Diode
          o Diode I/V Curve
          o Half-Wave Rectifier
          o Full-Wave Rectifier
          o Full-Wave Rectifier w/ Filter
          o Diode Limiter
          o Zener Diodes
                + Zener I/V Curve
                + Zener Voltage Reference
                + Zener Voltage Reference w/ Follower
          o DC Restoration
          o Spike Generator
          o Voltage Multipliers
                + Voltage Doubler
                + Voltage Tripler
                + Voltage Quadrupler
          o AM Detector
          o Waveform Clipper
          o Triangle-to-Sine Converter
    * Op-Amps
          o Op-Amp
          o Op-Amp Feedback
          o Amplifiers
                + Inverting Amplifier
                + Noninverting Amplifier
                + Follower
                + Differential Amplifier
                + Summing Amplifier
                + Log Amplifier
                + Class-D Amplifier
          o Half-Wave Rectifier (inverting)
          o Peak Detector
          o Integrator (inverting)
          o Differentiator (inverting)
          o Schmitt Trigger
          o Oscillators
                + Relaxation Oscillator
                + Triangle Wave Generator
                + Sawtooth Wave Generator
                + Sine Wave Generator
                + Voltage-Controlled Oscillator
                + Phase-Shift Oscillator
                + Phase-Shift Oscillator Filter
          o Negative Impedance Converter
          o Gyrator
          o Capacitance Multiplier
          o Howland Current Source
          o Current-to-Voltage Converter
          o Voltage Regulator
    * MOSFETs
          o n-MOSFET
          o p-MOSFET
          o Switch
          o Source Follower
          o Current Source
          o Current Ramp
          o Current Mirror
          o Common-Source Amplifier
          o CMOS Inverter
          o CMOS Inverter (w/capacitance)
          o CMOS Inverter (slow transition)
          o CMOS Transmission Gate
          o CMOS Multiplexer
          o Sample-and-Hold
          o Delayed Buffer
          o Leading-Edge Detector
          o Switchable Filter
          o Voltage Inverter
          o Inverter Amplifier
          o Inverter Oscillator
          o Logic
                + CMOS NAND
                + CMOS NOR
                + CMOS XOR
                + CMOS Flip-Flop
                + CMOS Master-Slave Flip-Flop
                + Ternary Logic Inverter
    * Transistors (Bipolar)
          o NPN Transistor (Bipolar)
          o PNP Transistor (Bipolar)
          o Switch
          o Emitter Follower
          o Common-Emitter Amplifier
          o Unity-Gain Phase Splitter
          o Schmitt Trigger
          o Current Source
          o Current Source Ramp
          o Current Mirror
          o Differential Amplifiers
                + Differential Amplifier: Common-Mode Input
                + Differential Amplifier: Common-Mode w/Current Source
          o Push-Pull Follower
                + Simple Push-Pull Follower, with Distortion
                + Improved Push-Pull Follower
          o Multivibrators
                + Bistable Multivibrator (Flip-Flop)
                + Astable Multivibrator (Oscillator)
                + Monostable Multivibator (One-Shot)
          o Oscillators
                + Colpitts Oscillator
                + Hartley Oscillator
                + Emitter-Coupled LC Oscillator
          o Logic
                + RTL Inverter
                + RTL NAND
                + DTL NAND
                + TTL NAND
                + TTL NOR
                + ECL NOR/OR
    * Combinational Logic
          o Exclusive OR
          o Half Adder
          o Full Adder
          o 1-of-4 Decoder
          o 2-to-1 Mux
          o Majority Logic
          o 2-Bit Comparator
          o 7-Segment LED Decoder
    * Sequential Logic
          o Flip-Flops
                + SR Flip-Flop
                + Clocked SR Flip-Flop
                + Master-Slave Flip-Flop
                + Edge-Triggered D Flip-Flop
                + JK Flip-Flop
          o Counters
                + 4-Bit Ripple Counter
                + 8-Bit Ripple Counter
                + Synchronous Counter
                + Decimal Counter
                + Gray Code Counter
                + Johnson Counter / Decade Counter
          o Divide-by-2
          o Divide-by-3
          o Traffic Light
          o Dynamic RAM
    * 555 Timer Chip
          o 555 Square Wave Generator
          o 555 Internals
          o 555 Sawtooth Oscillator
          o 555 Low-duty-cycle Oscillator
          o 555 Monostable Multivibrator
          o 555 Pulse Sequencer
          o 555 Pulse Width Modulator
          o 555 Schmitt Trigger (inverting)
          o 555 Missing Pulse Detector
    * Transmission Lines
          o Simple Transmission Lines
          o Standing Wave on a Transmission Line
          o Termination of a Transmission Line
          o Mismatched transmission lines (Pulse)
          o Mismatched transmission lines (Standing Wave)
          o Impedance Matching (L-Section)
          o Impedance Matching (Shunt Stub)
          o Stub Frequency Response
          o Low-Pass Filter
          o Light Switch
    * Memristors
          o Memristor
          o Memristor Response to Sine Wave
          o Memristor Response to Square Wave
          o Memristor Response to Triangle Wave
          o Memristor Hard-Switching 1
          o Memristor Hard-Switching 2
    * Tunnel Diodes
          o Tunnel Diode I/V Curve
          o Tunnel Diode Relaxation Oscillator
    * Spark Gaps
          o Sawtooth Oscillator
          o Tesla Coil
          o Marx Generator
