[Hoje às 19:32]
[Hoje às 19:24]
[Ontem às 22:54]
[Ontem às 12:02]
[Ontem às 02:23]
Projeto Maquete por Hugu
Password por KammutierSpule
Autor Tópico: Complex Sound Generator IC is Back  (Lida 1457 vezes)
Offline mauricio
    • http://www.dvpt.com
« em: 01 de Janeiro de 2009, 17:09 »
Quer fazer o seu Robot falar?
Depois de quase 30 anos a Texas volta a fabricar um chip "mágico" ...
Ler mais em: http://www.popsci.com/diy/article/2008-12/complex-sound-generator-ic-back
After nearly a 30-year absence from the hobby electronics market, the Texas Instruments SN76477N Complex Sound Generator IC is now for sale at BG Micro. It's just like 1973 all over again. Bomb blasts, propeller sounds, snare drums, and sci-fi sound effects will all be back in vogue with the return of this super synthesizer chip.
Move over Monome: with just a fist-full of resistors, capacitors, potentiometers, and switches, the SN76477N can produce sounds that a microcontroller could only dream about. Featuring a super low-frequency oscillator, voltage-controlled oscillator, noise generator, and a mixer all on the same chip, the SN76477N can easily outpace most microcontroller-based synthesizers. Throw in a simple 9V power source and you're talkin' about a portable synth that can plug into any amp for some serious sound-makin'.
Thoughtfully, BG Micro has unearthed a nifty compilation of circuit data for the SN76477N and glued everything together into one tidy PDF. They even somehow managed to include a clipping from a Forrest M. Mims III engineering notebook featuring the SN76477N. That clipping alone is worth experimenting with this venerable sound generator chip.
« Última modificação: 01 de Janeiro de 2009, 17:31 por TigPT »
Re:Complex Sound Generator IC is Back
« Responder #1 em: 01 de Janeiro de 2009, 20:45 »
Muito interessante, se tivesse tempo metia o smalluino falante ;)
Offline defer
« Responder #2 em: 01 de Janeiro de 2009, 21:50 »
Isto emite som, assim sem mais nada?
« Responder #3 em: 01 de Janeiro de 2009, 22:14 »
Sintetiza, depois tens que ligar a um aplificador, podes usar um simples daqueles dos radios ou leitores de mp3 dos chineses :P
