[Hoje às 21:57]
Autor Tópico: Ajuda a programar arduino  (Lida 7371 vezes)
Offline The Wolfman
Re: Ajuda a programar arduino
« Responder #15 em: 04 de Maio de 2010, 23:53 »
Bem, por hoje fico assim. Amanhã vou testar :D
int duration_frt;
int distance_frt;
int srf_frt = 4;
int duration_esq;
int distance_esq;
int srf_esq = 5;
int duration_dir;
int distance_dir;
int srf_dir = 6;
int ldr = 0;
int valor_ldr = 5;
int led_ldr = 13;
int motor_esq[] = {2, 3};
int motor_dir[] = {7,8};
int i;
int led_vitima = 12;
void setup(){
Serial.begin(9600);
for(i = 0; i < 2; i++){
  pinMode(motor_esq[i], OUTPUT);
  pinMode(motor_dir[i], OUTPUT);
void loop(){
  pinMode(srf_frt, OUTPUT);
  digitalWrite(srf_frt, LOW);
  delayMicroseconds(2);
  digitalWrite(srf_frt, HIGH);
  delayMicroseconds(10);
  pinMode(srf_frt, INPUT);
  duration_frt = pulseIn(srf_frt, HIGH);
  distance_frt = duration_frt/58;
  pinMode(srf_esq, OUTPUT);
  digitalWrite(srf_esq, LOW);
  digitalWrite(srf_esq, HIGH);
  pinMode(srf_esq, INPUT);
  duration_esq = pulseIn(srf_esq, HIGH);
  distance_esq = duration_esq/58;
  pinMode(srf_dir, OUTPUT);
  digitalWrite(srf_dir, LOW);
  digitalWrite(srf_dir, HIGH);
  pinMode(srf_dir, INPUT);
  duration_dir = pulseIn(srf_dir, HIGH);
  distance_dir = duration_dir/58;
  digitalWrite(motor_esq[0], HIGH);
  digitalWrite(motor_esq[1], LOW);
  digitalWrite(motor_dir[0], HIGH);
  digitalWrite(motor_dir[1], LOW);
  ldr = analogRead(valor_ldr);
  digitalWrite(led_ldr, HIGH);
  digitalWrite(led_vitima, LOW);
  if (ldr > 500)
  pinMode(led_vitima, OUTPUT);
  digitalWrite(led_vitima, HIGH);
  if (distance_frt <= 4)
  digitalWrite(motor_esq[0], LOW);
  digitalWrite(motor_dir[0], LOW);
  delay(1000);
  digitalWrite(motor_esq[1], HIGH);
  digitalWrite(motor_dir[1], HIGH);
  delay(1000);
  delay(1000);
  if (distance_frt && distance_esq <= 4)
  delay(1000);
  delay(1000);
  delay(1000);
  if (distance_frt && distance_dir <= 4)
  delay(1000);
  delay(1000);
  delay(1000);
  Serial.println(distance_frt);
  delay(100);
« Responder #16 em: 11 de Maio de 2010, 19:40 »
Como o é que o projecto ficou?
Fotos da versão final para o pessoal e um pequeno resumo do que aprenderam!? ;D
Offline The Wolfman
« Responder #17 em: 11 de Maio de 2010, 21:16 »
Sim, eu não me esqueci ;)
Eu tratei da programação ao inicio, mas um colega meu depois começou a inventar (pelo que vi dos testes dele, já misturava whiles dentro de if's) LOOL!
O que interessa é que tendo em conta os nossos contratempos, conseguimos meter o motor a funcionar.
Contratempos esses:
-2 Reguladores 7805 queimados;
-2 Pontes H SN754410NE;
-1 Picaxe 28X1;
-1 pololu TB66FNG12 (ainda estou para descobrir como aquilo se queimou --');
-1 Mini metal gearmotor 100:1 com as engrenagens rebentadas;
-Uma carrada de LED's queimados;
Especialmente devido a contratempos como ter de estar a trocar de chassis de um dia para o outro, não vou postar aqui ainda o código, visto que não está ainda tudo funcional :s
De qualquer maneira, o meu trabalho foi dos 3 melhores da escola!!!
Um amigo meu vai-me passar as fotografias TODAS do desenvolvimento do projecto e eu depois posto :D
Queria deixar aqui um agradecimento especial ao TigPT e ao Fifas porque são uns bacanos e a ajuda deles foi muito preciosa, sem a ajuda destas duas pessoas, não conseguiríamos alcançar os nossos objectivos!
