Autor Tópico: Sensor SRF02  (Lida 2048 vezes)
Offline joao1996f
Sensor SRF02
« em: 07 de Dezembro de 2012, 23:00 »
Olá, o meu Arduino chegou hoje juntamente com um lcd e um sensor ultra-sons SRF02.
Queria meter a distancia que  sensor deteta no lcd, mas so consigo na porta serial.
  SRF02 sensor reader
 language: Wiring/Arduino Reads data from a Devantech SRF02 ultrasonic sensor.
 Should also work for the SRF08 and SRF10 sensors as well.
Sensor connections:
 SDA - Analog pin 4
 SCL - Analog pin 5
created 5 Mar. 2007
 by Tom Igoe
// include Wire library to read and write I2C commands:
//#include
#include <Wire.h>
#include <SoftwareSerial.h>
// the commands needed for the SRF sensors:
#define sensorAddress 0x70
#define readInches 0x50
// use these as alternatives if you want centimeters or microseconds:
#define readCentimeters 0x51
#define readMicroseconds 0x52
// this is the memory register in the sensor that contains the result:
#define resultRegister 0x02
void setup()
  // start the I2C bus
  pinMode(2, OUTPUT);
  pinMode(3, OUTPUT);
  pinMode(4, OUTPUT);
  Wire.begin();
  // open the serial port:
  Serial.begin(9600);
void loop()
  // send the command to read the result in inches:
  sendCommand(sensorAddress, readCentimeters);
  // wait at least 70 milliseconds for a result:
  delay(70);
  // set the register that you want to reas the result from:
  setRegister(sensorAddress, resultRegister);
// read the result:
  int sensorReading = readData(sensorAddress, 2);
  // print it:
if(sensorReading < 25)
digitalWrite(2, HIGH);   // set the verm LED on
digitalWrite(3, LOW);
digitalWrite(4, LOW);
if(sensorReading > 75)
digitalWrite(4, HIGH);   // set the verd LED on
digitalWrite(2, LOW);
if((sensorReading > 25) && (sensorReading < 75))
digitalWrite(3, HIGH);   // set the amar LED on
  Serial.print("distancia: ");
  Serial.print(sensorReading);
  Serial.println(" cm");
  // wait before next reading:
  delay(270);
  SendCommand() sends commands in the format that the SRF sensors expect
void sendCommand (int address, int command) {
  // start I2C transmission:
  Wire.beginTransmission(address);
  // send command:
  Wire.send(0x00);
  Wire.send(command);
  // end I2C transmission:
  Wire.endTransmission();
  setRegister() tells the SRF sensor to change the address pointer position
void setRegister(int address, int thisRegister) {
  // send address to read from:
  Wire.send(thisRegister);
readData() returns a result from the SRF sensor
int readData(int address, int numBytes) {
  int result = 0;        // the result is two bytes long
// send I2C request for data:
  Wire.requestFrom(address, numBytes);
  // wait for two bytes to return:
  while (Wire.available() < 2 )   {
    // wait for result
  // read the two bytes, and combine them into one int:
  result = Wire.receive() * 256;
  result = result + Wire.receive();
  // return the result:
  return result;
« Última modificação: 07 de Dezembro de 2012, 23:11 por senso »
Re: Sensor SRF02
« Responder #1 em: 07 de Dezembro de 2012, 23:11 »
Está mais legivel assim.
Pois, não tens código para escrever nada para o lcd, é normal que não mostre nada.
Offline joao1996f
Re: Sensor SRF02
« Responder #2 em: 07 de Dezembro de 2012, 23:14 »
Resolvido
