Autor Tópico: [Tutorial] Faz a tua própria PCB  (Lida 204435 vezes)
Re: [Tutorial] Faz a tua própria PCB
« Responder #285 em: 15 de Fevereiro de 2014, 22:36 »
Tão barato não Europa não conheço nada
« Responder #286 em: 15 de Fevereiro de 2014, 23:06 »
Existe algum serviço semelhante ao oferecido pela olimex na europa?
Que eu saiba a olimex já não fabrica PCBs há algum tempo...
para ser sincero não compro na Olimex vai para mais de 1 ano, mas penso que ainda
fazem as PCBs, dá uma vista de olhos aqui:  https://www.olimex.com/PCB/
« Responder #287 em: 16 de Fevereiro de 2014, 02:10 »
Não viste a página?  ???
PCB
IMPORTANT NOTICE
Dear Customers,
We are sorry to inform you that the PCB prototype service is temporary suspended due to the lack of free capacity.
As you know we had long vacation in August and people was keep sending PCB prototypes even while we were on vacation, this created so huge backlog that we couldn't repond to all PCB jobs for more than a week after we resumed work.
On top of this our lines usually are loaded close to 100% with the production of our own development boards and having such additional big load start to mess with our production schedules and delay our development boards production and shipments which is unacceptable.
We are sorry for this situation and we expect this to improve in the next months, so we can re-enable this service at fist possibility, but effectively from September 17th the PCB prototype service is suspended.
All orders which are quoted and accepted before with PO forms will be shipped (some of them may be shipped with delay) but new orders will not be processed until we re-enable this service.
« Responder #288 em: 16 de Fevereiro de 2014, 02:21 »
Ops, escapou-me essa parte, pois sendo assim nada feito na Olimex.
Por acaso a qualidade deles era muito boa, vamos esperar para ver no
que vai dar.
« Responder #289 em: 16 de Fevereiro de 2014, 15:10 »
Primeiro vou exprimentar com lampadas flurescentes normais, e ver quais são os resultados.  Fica muito mais em conta que uma lampada uv. Aqui nos chineses custa 1.5€.
 Se eu um dia quiser mais tarde mudar para uv já sei +/- o que ir comprar.
Offline Tech_JA
« Responder #290 em: 18 de Fevereiro de 2014, 09:14 »
... Quando ao ataque à placa estas até podem ser atacadas por vinagre ...
Tayeb,
Obrigado por esta dica e pelo respectivo link.
Deixei de fazer pcbs em casa por causa dos quimicos usados mas vou ter de experimentar a corrosão com o vinagre (mais agua oxigenada e sal)
Já agora, como andam na "moda" as placas coloridas, deixo aqui uns exemplo de como colorir PCBs:
http://www.aaronalai.com/pcb-board-dyeing
Offline Kristey
« Responder #291 em: 19 de Fevereiro de 2014, 00:26 »
StarRider, podes dar mais infos ssobre essas lojas chinesas?
Eu nao me importo de esperar desde que a qualidade seja boa, pois tenho pouco dinheiro para gastar e preisava de fazer umas pcb's
« Responder #292 em: 19 de Fevereiro de 2014, 01:08 »
O que agora tenho usado é a Elecrow, menos de 15€ por 10 pcb's de 10x10cm  :o
Offline Kristey
« Responder #293 em: 19 de Fevereiro de 2014, 01:26 »
Podes dar mais detalhes senso?
Como o tempo de entrega e a qualidade das mesmas?
Obrigado por responderes.
Eu tenho umas que vou fazer na g7 porque provavelmente preciso com urgencia quando as tiver desenhado, mas por agora nao é necessario.
EDIT: La tem a opção para escolheres as Layers isso sao as camadas certo (TOP e BUTTON)
A minha so tem uma camada, logo seleciono 1 certo?
Estou NESTE produto ja agora
Posso enviar o ficheiro *.brd do eagle? E eles tratam do resto? Não percebi essas instruções.
« Última modificação: 19 de Fevereiro de 2014, 01:37 por Kristey »
« Responder #294 em: 19 de Fevereiro de 2014, 02:00 »
Não faço ideia se aceitam ficheiros eagle, mas é provavel que não, tens de usar o CAM e gerar os gerbers usando o job deles, ou da seeed ou da itead, isso gera 8 ficheiros gerber, silk, solder, cooper top e bottom são os que interessam e os drill file em txt.
O tempo de entrega com portes de meia duzia de € é o tipico 3 semanas.
Offline jmiguelff
« Responder #295 em: 19 de Fevereiro de 2014, 10:58 »
Esta pergunta vai ser muito estúpida mas eu nunca usei Eagle. O Eagle não gera gerbers?
« Responder #296 em: 19 de Fevereiro de 2014, 11:10 »
O CAM a que me refiro neste caso é a  janela no eagle onde configuras qual layer gera cada gerber e como é que ele é gerado, se invertido, tipo de formato, e mais umas coisas.
« Responder #297 em: 19 de Fevereiro de 2014, 11:12 »
Gera.
A olimex tinha umas instruções decentes: https://www.olimex.com/PCB/FAQ/Eagle/
Offline jmiguelff
« Responder #298 em: 19 de Fevereiro de 2014, 12:30 »
Obrigado já estou mais esclarecido. Eu comecei por fazer PCBs em Orcad depois passei para o DesignSpark (que é o que uso para os meus projectos) e agora no trabalho uso Altium.
Não consigo arranjar motivos suficientes para passar para Eagle :p
« Responder #299 em: 19 de Fevereiro de 2014, 21:55 »
sim o eagle gera os gerbers files, mas as empresas de pcbs so querem os ficheiros gerber porque é o que usam para o fabrico das pcbs.
Ha empresa que tb aceitam os eagles files e files de outros softwares, mas eles sao capazes de cobrar pelo tratamento e conversao dos ficheiros para gerber files..
Fazer pcbs para prototipos ou para testar, nada melhor que a G7!  8)
Depois se quiserem varias pcbs, ja todas pipis entao nada melhor que fazer pcbs profissionais! (a g7 tb faz pcbs profissionais, mas requisita minimo de projectos para compensar mandar fazer todas as pcbs por painel e assim obter preços mais em conta. Claro que qtos mais pedirem, mais pcbs se reunem e mais depressa se mandam fazer..)
Fazer pcbs profissionais utiliza mta mao de obra e varias maquinas/equipamentos. É complicado a europa conseguir combater os preços dos chinocas, porque os chinocas trabalham a pao e agua, as maquinas sao equipamentos quase em série onde se mete um painel num lado e saem logo as pcbs feitas no outro lado! (nao é, mas é quase!:P), os quimicos sao baratos e nem devem ter leis para os tratamentos residuais, os gaijos devem despejar no rio mais proximo qdo a cisterna estiver cheia! E depois, como fazem pcbs ao montão, eles planificam os projectos pelos paineis para rentabilizar o painel ao maximo, e logo ha menos desperdicios e o trabalho pra fazerem um painel cheio com pcbs ou fazer uma painel, so com uma ou duas pcbs é igual..
Em portugal, as empresas teem poucos pedidos e normalmente pedem as pcbs com urgencia, elas podem usar paineis mais pequenos, mas nao conseguem rentabilizar os projectos por painel e logo, a pcb fica com preços um bocado altos.
