Autor Tópico: NOVO PREÇO Lcd 2.8" Touch e Board  (Lida 4603 vezes)
Offline camolas
« em: 06 de Outubro de 2010, 16:50 »
Boas malta,
Tenho para vender esta board com o 2.8" lcd touch esta como nova apenas a liguei para ver se estava todo bem ela tras um programa demo para exprimentarmos o touch e esta tudo ok.
Vendo por ter de abandonar por agora o projecto ( falta de €€ !! ). Tambem fabrico tb PCB pelo metodo de fresagem por CNC se estiverem intressados por favor contactem para oriun1@clix.pt.
Sou de Penafiel e posso entregar em mao na zona do grande Porto.
Obrigado e um abraço para todos.
NOVO PREÇO Lcd e board 30€ Portes incluidos.
[/b][/color][/size]
Carateristiscas e funçoes.
 CPU: STM32F103RBT6; (LQFP64-pin, on-chip integrated 128K flash, 20KRAM, 16Bit A / D; PWM, CAN, USB and other resources)
 With a 2.8-inch TFT true color touch screen module, color touch module configuration ADS7843 (or RSM1843 instead) controller, support for a SD card (SPI mode) can be used to store pictures, in support of AT45DBxxx of a DATA FLASH (can be used for storage)
 USB interface, make USB experiment
 USB to RS232 interface (ISP download), make RS232 communicate experiment
 AD adjuster
 Standard ARM JTAG 20 pin
 A RTC in support, the four users LED lights, a power indicator light, a USB communication indicator, two user keys
 8MHz crystal,32.768KHz crystal
 USB power supply or power supply by J-Link
 All I / O port through the standard pitch leads 2.54MM
 Board Size: 82MM X 68MM
Rich in routines, not only functional modules MDK-board test-source: LED lights examples, RTC, USB, SD card, ADC, touch-screen test, TFT LCD screen test .....
but also there are successful transplantation UCOS2, UCGUI a number of routines can be directly applied to industrial control equipment or hand-held instrument of human-computer interface design, so that your product from the monotony of black and white, into the colorful world! Inspire your design inspiration!
« Última modificação: 27 de Dezembro de 2010, 15:05 por camolas »
Re: NOVO PREÇO Lcd 2.8" Touch e Board
« Responder #1 em: 10 de Março de 2011, 00:13 »
podes deixar um video do demo e o touchescreen a rullar?
Offline camolas
« Responder #2 em: 28 de Junho de 2011, 17:44 »
Boas desculpa a demora a responder mas estive fora...
Abx e obg
« Responder #3 em: 28 de Junho de 2011, 19:58 »
a board tem bootloader usb ou serial? é preciso ter um stm32 programador?
Offline camolas
« Responder #4 em: 01 de Julho de 2011, 17:48 »
Boas,  bootloader  é feito por um J-TAG ou J-LINK (20 PIN) ou seja é necessario um J-TAG ou J-LINK.
Offline GnGz
« Responder #5 em: 02 de Julho de 2011, 11:37 »
Ele perguntou se a board já tinha bootloader
Offline camolas
« Responder #6 em: 04 de Julho de 2011, 15:42 »
julgo que n tras ou seja penso ser necessario um desses programadores para meter novo programa.
Cumps e obg.
