Autor Tópico: Procura fuso esferas  (Lida 6483 vezes)
Offline weed2all
« em: 29 de Dezembro de 2016, 01:22 »
Boa noite...estou a procura um fuso de esferas 1605, ou seja o que realmente me faz falta e só a porca de esferas...mas caso alguém tem a venda o conjunto de fuso+porca aguardo repostas  com o valor
Enviado do meu SM-G928F através de Tapatalk
« Última modificação: 30 de Dezembro de 2016, 14:48 por weed2all »
Offline weed2all
Re: Procura fuso esferas
« Responder #1 em: 01 de Janeiro de 2017, 08:13 »
Ninguém?
Offline downloader
« Responder #3 em: 02 de Janeiro de 2017, 23:32 »
Andei há uns tempos de volta desse tipo de coisas ...
Aqui ficam os meus bookmarks:
http://www.zappautomation.co.uk/
http://www.directindustry.com/industrial-manufacturer/trapezoidal-screw-81151.html
http://www.pic-design.com/lead-screws.html
http://www.solsylva.com/cnc/acme_rod.shtml
http://www.reball.co.uk/?gclid=COK26ZmzzrsCFWnjwgodVTgAOQ
http://www.directindustry.com/prod/huco-engineering-industries/custom-rolled-trapezoidal-threaded-screws-7162-460107.html
https://damencnc.com/en/components/mechanical-parts/trapezium-nuts---spindles
http://www.maedler.ch/product/1643/1620/din-103-trapezgewindespindeln-und-muttern-zweigaengig-rechts
http://www.skf.com/pt/products/linear-motion/ball-and-roller-screws/index.html
http://www.igus.pt/wpck/2371/drylin_trapezgewindemutter
http://www.igus.co.uk/wpck/3810/DryLin_Trapezgewindespindel
http://www.igus.co.uk/wpck/9922/N13_13_0_Overview_drylin_Gewindetriebe?playlistid=40
http://www.mooreinternational.co.uk/
http://www.mooreinternational.co.uk/?gclid=COL00ZWzzrsCFUkCwwodPQQAOg
http://www.rpmechatronics.co.uk/shop/index.php?cPath=441&gclid=CMX1ipmzzrsCFfMctAodDVYAfg
http://www.skf.com/pt/products/linear-motion/ball-and-roller-screws/ball-screws/miniature-range/index.html
http://www.zappautomation.co.uk/index.php/mechanical-products/ballscrews/c7-ballscrews/miniature-ballscrews-6-12mm-diameter.html
http://www.rfportugal.com/portuguese/produtos/linear.php
! No longer available
http://www.ondrives.com/c/500/square-trapezoidal-nuts
http://www.worldofcnc.com/collections/trapezoidal/products/tr10x2d-trapezoidal-right-hand-spindle-leadscrew-din103-c15-c35
http://www.ebay.co.uk/itm/TR10x2D-Trapezoidal-Spindle-Acme-Ballscrew-Leadscrew-/310185130078
http://www.ebay.com/itm/TR12x2Dx1000mm-2mm-Pitch-Trapezoidal-Acme-Ballscrew-Leadscrew-Fine-Pitch-/221227215073?pt=UK_BOI_Metalworking_Milling_Welding_Metalworking_Supplies_ET&hash=item33822b68e1
http://www.inkoma.de/inkoma-group-english/albert-spindles.htm
http://www.aben.eu/en/product-range/ball-screws/trapezoidal-spindles/
http://www.kammerer-gewinde.com/products/knuckle-threads/trapezoidal-spindles/
http://www.maedler.ch/product/1643/1620/2028/2031/trapezgewindespindeln-eingaengig-rechts-stahl-laenge-1m
Offline weed2all
« Responder #4 em: 05 de Janeiro de 2017, 06:07 »
obrigado serra cabo...estou a seguir o seu canal no YouTube...
a minha questao era se alguém aqui em Portugal tinha a venda...pois do eBay posso mandar vir...mas nao queria estar tanto tempo a espera
« Responder #5 em: 05 de Janeiro de 2017, 10:42 »
... pois. Em Portugal a regra geral é: nunca há resposta. De certa forma já desisti de enviar mails para o comércio nacional. A regra geral é nunca haver resposta ou, quando há, fico coma  impressão que não leram o meu mail. Respondem qualquer coisa. Parece que não gostam de clientes novos, só os "veteranos" ... que, a prazo, os deixarão sem clientes.
Para esse tipo de material a minha primeira escolha vai para os ingleses. Para material não trivial (quantias acima dos 100 euros) o material chega por DHL ou UPS e chega em poucos dias. 6ª feira passada encomendei material daqui (http://www.pcb-soldering.co.uk/) via e-bay. Chegou ontem.
Voltando à vaca fria e a propósito de uns quantos comentários em jeito de saudade relativamente ao desaparecimento de uma incontornável figura do comércio de electrónica em Lisboa, o Filipe Albarrão, recordei uma outra figura com que Albarrão tinha trabalhado antes de fundar a Minitron: o Albarrão tinha trabalhado na Soc. Zickermann, na mesma rua. Nesse balcão, nos anos 70, estacionava ainda um alemão, cujo nome desconheço, e que, depreendia eu, faria parte da família Zickermann. Esse alemão chamava regularmente a atenção de outras pessoas que trabalhavam igualmente atrás do balcão, que os toscos de hoje serão os clientes de amanhã, política que o Albarrão sempre seguiu, muito embora a saída dele da Zickermann tenha aniquilado o respectivo comércio de componentes electrónicos. O alemão afastou-se e, quem lá ficou, não só detestava toscos como não percebia nada daquilo.
Abraço
SC
« Responder #6 em: 05 de Janeiro de 2017, 11:13 »
Haver até há, o problema é que tens de ser familiar ou lá perto... E emails esquece, em Portugal ou ligas para lá, ou vais lá pessoalmente, email é uma coisa muito avant garde..
Offline weed2all
« Responder #7 em: 05 de Janeiro de 2017, 12:14 »
muito obrigado com a sua resposta breve...fiquei muito impressionado com sua maneira calma de falar e explicar realmente como as coisas estao...sendo o relato acima vou mesmo ter que encomendar do eBay ou coisa que a vale...
P.S.
aguardo mais uns videos seus no YouTube...tenho mesmo prazer de o seguir...continuacao de um FELIZ ANO !!!
Offline weed2all
« Responder #8 em: 05 de Janeiro de 2017, 12:20 »
ou entao alguém aqui do forum que tem a mais que pode vender...saliento que o que me faz mais falta e apenas a porca de esferas...fuso ja o tenho..tenho a porca também...apenas tirei do fuso pra cima de um pedaco de tudo de 15mm e guardei...nao sei onde guardei..possivelmente de certeza que parou no caixote  de lixo...pois há 3 semanas ando a procura e não encontro...
« Responder #9 em: 06 de Janeiro de 2017, 09:30 »
Tenho estado a fazer algumas alterações à oficina, nomeadamente à habitabilidade: colocar uma cortina, controlar a humidade, instalar um ar condicionado, instalar um sistema de extracção de fumo e ... o eterno arrumar, arrumar, arrumar ...
Estou simultaneamente a preparar o espaço do andar de cima para montar a bancada de electrónica.
Não posso fazer grandes tiradas porque as costelas ainda me doem.
Bom ano novo.
SC
Offline weed2all
« Responder #10 em: 06 de Janeiro de 2017, 17:46 »
pois...teve um acidente...as melhores rápidas e que corra tudo bem...
