Boas pessoal
Alguem pode me controlar aqui a _config deste bootloader
o meu quartz é de 4 mhz
radix DEC
LIST P=18F2685 ; change also: Configure->SelectDevice from Mplab
xtal EQU 4000000 ; you may want to change: _XT_OSC_1H _HS_OSC_1H _HSPLL_OSC_1H
baud EQU 19200 ; standard TinyBld baud rates: 115200 or 19200
; The above 3 lines can be changed and buid a bootloader for the desired frequency (and PIC type)
; Tiny Bootloader 18F series Size=100words
; claudiu.chiculita@ugal.ro
; http://www.etc.ugal.ro/cchiculita/software/picbootloader.htm
;thanks to Inácio
#include "icdpictypes.inc" ;takes care of: #include "p18fxxx.inc", max_flash, IdTypePIC
#include "spbrgselect.inc" ; RoundResult and baud_rate
#define first_address max_flash-200 ;100 words
__CONFIG _CONFIG1H , _OSC_XT_1H
__CONFIG _CONFIG2L , _BOREN_BOHW_2L & _BORV_3_2L & _PWRT_ON_2L
; _BORV_0_2L , _BORV_1_2L , _BORV_2_2L , _BORV_3_2L
__CONFIG _CONFIG2H , _WDT_OFF_2H & _WDTPS_128_2H
__CONFIG _CONFIG4L , _XINST_OFF_4L & _BBSIZ_1024_4L & _STVREN_ON_4L & _LVP_OFF_4L & _DEBUG_OFF_4L ; _STVREN_ON_4L --Stack ligado
__CONFIG _CONFIG5L, 0xFF ;No code protection.
__CONFIG _CONFIG5H, 0xFF ;
__CONFIG _CONFIG6L, 0xFF ;
__CONFIG _CONFIG6H, 0XFF ;
__CONFIG _CONFIG7L, 0xFF ;
__CONFIG _CONFIG7H, 0xFF ;
;----------------------------- PROGRAM ---------------------------------
cblock 0
crc
i
cnt1
cnt2
cnt3
counter_hi
counter_lo
flag
endc
cblock 10
buffer:64
dummy4crc
endc
SendL macro car
movlw car
movwf TXREG
endm
;0000000000000000000000000 RESET 00000000000000000000000000
ORG 0x0000
GOTO IntrareBootloader
;view with TabSize=4
;&&&&&&&&&&&&&&&&&&&&&&& START &&&&&&&&&&&&&&&&&&&&&&
;---------------------- Bootloader ----------------------
;PC_flash: C1h U H L x ... <64 bytes> ... crc
;PC_eeprom: C1h 40h EEADR EEDATA 0 crc
;PC_cfg C1h U OR 80h H L 1 byte crc
;PIC_response: type `K`
ORG first_address ;space to deposit first 4 instr. of user prog.
nop
nop
nop
nop
org first_address+8
IntrareBootloader
;init serial port
movlw b'00100100'
movwf TXSTA
movlw spbrg_value
movwf SPBRG
movlw b'10010000'
movwf RCSTA
;wait for computer
rcall Receive
sublw 0xC1 ;Expect C1h
bnz way_to_exit
SendL IdTypePIC ;send PIC type
MainLoop
SendL 'K' ; "-Everything OK, ready and waiting."
mainl
clrf crc
rcall Receive ;Upper
movwf TBLPTRU
movwf flag ;(for EEPROM and CFG cases)
rcall Receive ;Hi
movwf TBLPTRH
movwf EEADR ;(for EEPROM case)
rcall Receive ;Lo
movwf TBLPTRL
movwf EEDATA ;(for EEPROM case)
rcall Receive ;count
movwf i
incf i
lfsr FSR0, (buffer-1)
rcvoct ;read 64+1 bytes
movwf TABLAT ;prepare for cfg; => store byte before crc
rcall Receive
movwf PREINC0
decfsz i
bra rcvoct
tstfsz crc ;check crc
bra ziieroare
btfss flag,6 ;is EEPROM data?
bra noeeprom
movlw b'00000100' ;Setup eeprom
rcall Write
bra waitwre
noeeprom
btfss flag,7 ;is CFG data?
bra noconfig
tblwt* ;write TABLAT(byte before crc) to TBLPTR***
movlw b'11000100' ;Setup cfg
rcall Write
bra waitwre
noconfig
;write
eraseloop
movlw b'10010100' ; Setup erase
rcall Write
TBLRD*- ; point to adr-1
writebigloop
movlw 8 ; 8groups
movwf counter_hi
lfsr FSR0,buffer
writesloop
movlw 8 ; 8bytes = 4instr
movwf counter_lo
writebyte
movf POSTINC0,w ; put 1 byte
movwf TABLAT
tblwt+*
decfsz counter_lo
bra writebyte
movlw b'10000100' ; Setup writes
rcall Write
decfsz counter_hi
bra writesloop
waitwre
;btfsc EECON1,WR ;for eeprom writes (wait to finish write)
;bra waitwre ;no need: round trip time with PC bigger than 4ms
bcf EECON1,WREN ;disable writes
bra MainLoop
ziieroare ;CRC failed
SendL 'N'
bra mainl
;******** procedures ******************
Write
movwf EECON1
movlw 0x55
movwf EECON2
movlw 0xAA
movwf EECON2
bsf EECON1,WR ;WRITE
nop
;nop
return
Receive
movlw xtal/2000000+1 ; for 20MHz => 11 => 1second delay
movwf cnt1
rpt2
clrf cnt2
rpt3
clrf cnt3
rptc
btfss PIR1,RCIF ;test RX
bra notrcv
movf RCREG,w ;return read data in W
addwf crc,f ;compute crc
return
notrcv
decfsz cnt3
bra rptc
decfsz cnt2
bra rpt3
decfsz cnt1
bra rpt2
;timeout:
way_to_exit
bcf RCSTA, SPEN ; deactivate UART
bra first_address
; After reset
; Do not expect the memory to be zero,
; Do not expect registers to be initialised like in catalog.
END
Zé Tretas
