LLM Crawlers por TigPT
[Hoje às 19:58]
Autor Tópico: Arduino 0017!  (Lida 4495 vezes)
Offline tcustodio
    • Youtube
Arduino 0017!
« em: 12 de Agosto de 2009, 02:27 »
aí está a nova versão, publicada à duas horas atrás
http://arduino.cc/en/Main/Software
Release notes:
    0017 - 2009.07.25
    [documentation / examples]
    * Many new and revised examples from Tom Igoe.
    [core / libraries]
    * Updated LiquidCrystal library by Limor Fried. See reference for details.
    * Updated Firmata library to version 2.1 (rev. 25).
    * Replaced the Servo library with one (MegaServo) by Michael Margolis.
    Supports up to 12 servos on most Arduino boards and 48 on the Mega.
    * Improving the accuracy of the baud rate calculations for serial
    communication (fixing double-speed problems on 8 MHz Arduino boards).
    Thanks to gabebear.
    [environment]
    * Synchronized with the Processing 1.0.3 code base (rev. 5503), bringing
    many improvements (listed below).
    * New icons and about image by Thomas Glaser (envis precisely).
    * Support for multiple sketch windows.
    * The serial monitor now has its own window.
    * Comment / Uncomment menu item (in Edit) and keyboard shortcut.
    * Increase and Decrease Indent menu items (in Edit) and keyboard shortcuts.
    * Support for third-party libraries in the SKETCHBOOK/libraries folder.
    * Libraries are now compiled with the sketch, eliminating the delay when
    switching boards and the need to delete .o files when changing library
    source code.
    * Arduino now comes as an app file (in a dmg) on the Mac.
    * Adding the Arduino Nano w/ ATmega328 to the Tools > Board menu.
Tiago Custódio,
jspgresende
Re:Arduino 0017!
« Responder #1 em: 12 de Agosto de 2009, 02:56 »
Acabei de experimentar, e definitivamente está MUITO melhor...
Para não falar que está muito mais leve...
Offline ghostbuster
Re:Arduino 0017!
« Responder #2 em: 12 de Agosto de 2009, 11:03 »
aprovado  ;D muito mais rapido a fazer o upload e o terminal em janela separada 5*
Online TigPT
Re:Arduino 0017!
« Responder #3 em: 12 de Agosto de 2009, 14:28 »
Ainda estou a fazer o download :)
Offline Capeleiro
Re:Arduino 0017!
« Responder #4 em: 12 de Agosto de 2009, 14:41 »
Também aprovo. E até que enfim uma versão compatível com os temas do Vista e do Seven...
Offline norbanvs
Re:Arduino 0017!
« Responder #5 em: 12 de Agosto de 2009, 19:58 »
Será que li bem? 12 servos?!?
Ligados a que pinos?
jspgresende
Re:Arduino 0017!
« Responder #6 em: 12 de Agosto de 2009, 23:50 »
tens que ter em conta que não estamos a falar de controlo de rotação contínua através de PWM, mas sim de impulsos que irão controlar a posição dos servos através da respectiva duração... portanto os 12 pinos são do [2 ao 13], visto que os impulsos são digitais.
Offline norbanvs
Re:Arduino 0017!
« Responder #7 em: 13 de Agosto de 2009, 03:39 »
Foi precisamente isso que eu estava a perguntar, normalmente quando falamos em servos, estamos a referir-nos aos servos standard, dos que vão de um lado para outro.
Sendo assim, por exemplo, já fica muito mais fácil criar um six-leg-arduino com perninhas bem articuladas. ;)
Offline DanBar
    • iCAR Lusorobotica Blog
Re:Arduino 0017!
« Responder #8 em: 13 de Agosto de 2009, 09:28 »
 ::) 12 servos só dá para criar four-leg-arduino com perninhas bem articuladas (3 servos por perna, incluido a coxa). ;D
Antigo Nick do Forum: iCAR
Projectos iCAR
icar.lusorobotica.com
DB@G
Re:Arduino 0017!
« Responder #9 em: 31 de Agosto de 2009, 12:56 »
A mim dame o erro:
could not find the main class: processing.app.Base. progam will exit
