Autor Tópico: [Vendo] Osciloscópio Portatil DSO QUAD SeedStudio - 4 canais  (Lida 3087 vezes)
Offline cmcta82
Vendo osciloscopio portatil da SeedStudio DSO QUAD:
http://www.seeedstudio.com/depot/dso-quad-4-channel-digital-storage-oscilloscope-p-736.html
- 4 channel Digital
- ARM cortex M3 (STM32F103VCT6) 32 bits platform, providing 72MS/s sampling rate with integrated FPGA and high speed ADC
- Internal 2MB USB disk could be used to store waveform, user application and upgrade firmware
Feature
Pocket size and light weight
Two 72MS/s analog channels, plus two digital channels
Signal Generator
Auto Measurement
Various Triggering Option
Easy waveform storage
Firmware upgrade
User applications
Open source
Specifications
Analog channel * 2 : [CH_A] [CH_B];
Digital channel * 2 : [CH_C] [CH_D];
Vertical Scale: 20mV-10V/div (x1 probe);
Vertical solution: 8 bit ;
Input coupling: AC/DC ;
Max input voltage: 80Vpp (x1 probe);
Storage: 4K per channel
Software trigger type: edge, pulse, level (to be added)
Hardware trigger type: edge
Trigger source: CH1/CH2/EXT
Test Signal generator: 10Hz to 1Mhz
Storage: internal 2MB USB disk
Auto measure: Vmax, Vmin, Vpp, Vavr, Vrms, Freq, Period, Pulse, Duty
Cursor measurement: Level, Voltage
Display mode: CH1, CH2, EXT, CH1+CH2, CH1-CH2, CH1*CH2
Sampling mode: real time
Sampling rate: 1kSa/s - 72MSa/S
Power: Lipo battery
Dimension: 98 * 60 * 14.5
Weight: 80g (without battery)
Accessories within Pack: 2 mueller mcx oscilloscope probe, 2 digital probe,
Pack list
DSO Quad X1
Operation manual X1
Battery X1
Mueller mcx oscilloscope probe X2
Digital probe X2
Muito pouco utilizado, se quiserem posso mandar algumas fotos, o equipamento está novo. Venda por falta de tempo para utilizar.
Preço 125€, novo a venda por quase 200€.
Re: [Vendo] Osciloscópio Portatil DSO QUAD SeedStudio - 4 canais
« Responder #1 em: 25 de Março de 2013, 18:11 »
125€ com portes incluidos?
ainda está dentro da garantia?
Offline cmcta82
« Responder #2 em: 26 de Março de 2013, 13:52 »
O valor são os 125€ com portes, se for da zona de Castelo Branco posso entregar em mão. Foi comprado na proto-pic em Abril 2012 portanto ainda está na Garantia, posso fornecer a factura. Aproveito para enviar algumas fotografias.
