Autor Tópico: incompatibilidade de megaservo com wire?  (Lida 3394 vezes)
Offline silva_p
« em: 16 de Maio de 2009, 19:26 »
Estou a tentar programar o arduino para mover 4 servos com a nunchuck mas quando mando compilar dá este erro:
hardware\libraries\Wire/Wire.h: In function 'void loop()':
hardware\libraries\Wire/Wire.h:30: error: local class 'class loop()::TwoWire' shall not have static data member 'uint8_t* loop()::TwoWire::rxBuffer'
hardware\libraries\Wire/Wire.h:31: error: local class 'class loop()::TwoWire' shall not have static data member 'uint8_t loop()::TwoWire::rxBufferIndex'
hardware\libraries\Wire/Wire.h:32: error: local class 'class loop()::TwoWire' shall not have static data member 'uint8_t loop()::TwoWire::rxBufferLength'
hardware\libraries\Wire/Wire.h:34: error: local class 'class loop()::TwoWire' shall not have static data member 'uint8_t loop()::TwoWire::txAddress'
hardware\libraries\Wire/Wire.h:35: error: local class 'class loop()::TwoWire' shall not have static data member 'uint8_t* loop()::TwoWire::txBuffer'
hardware\libraries\Wire/Wire.h:36: error: local class 'class loop()::TwoWire' shall not have static data member 'uint8_t loop()::TwoWire::txBufferIndex'
hardware\libraries\Wire/Wire.h:37: error: local class 'class loop()::TwoWire' shall not have static data member 'uint8_t loop()::TwoWire::txBufferLength'
hardware\libraries\Wire/Wire.h:39: error: local class 'class loop()::TwoWire' shall not have static data member 'uint8_t loop()::TwoWire::transmitting'
hardware\libraries\Wire/Wire.h:40: error: local class 'class loop()::TwoWire' shall not have static data member 'void (* loop()::TwoWire::user_onRequest)()'
hardware\libraries\Wire/Wire.h:41: error: local class 'class loop()::TwoWire' shall not have static data member 'void (* loop()::TwoWire::user_onReceive)(int)'
já utilizei ambas a bibliotecas em separado e ambas funcionam bem!
o código que estou a usar é este:
(o codigo da nunchuck é do guibot) ;)
#include <MegaServo.h>
#include "nunchuck.h"
// test sketch for MegaServo library
// this will sweep all servos back and forth once, then position according to voltage on potPin
#define gdPin  9
#define gePin 3
#define bPin   5
#define bbPin 7
MegaServo servogd;    // declare variables for up to eight servos
MegaServo servoge;
MegaServo servob;
MegaServo servobb;
int val0 =0;
int val1=0;
int val2 =0;
void setup()
  Serial.begin (9600);
   nunchuk_init ();
 delay(1000);
 servogd.attach(gdPin);     // attach a pin to the servos and they will start pulsing
  servoge.attach(gePin);
  servob.attach(bPin);
  servobb.attach(bbPin);
void loop()
  if (nunchuk_get_data()) {
      if (nunchuk_button_z & nunchuk_button_c) {
  int joy_x = nunchuk_joy_x;
         int joy_y = nunchuk_joy_y;
         if (joy_x > 215) {
                               val0 = val0 -1;
                               servob.write(val0);
Serial.println(val0);
         else if (joy_x < 40) {
                              val0 =val0 +1;
                             servob.write(val0);
      else {if (nunchuk_button_z) {
          if (joy_x > 215) {
                               val1 = val1 -1;
                               servobb.write(val1);
Serial.println(val1);
                              val1 =val1 +1;
else {if (nunchuk_button_c){
          if (joy_x > 215) {
                               val2 = val2 -1;
                               servogd.write(val2);
                               servoge.write(val2);
Serial.println(val2);
                              val2 =val2 +1;
   delay (20);
alguém sabe o que se passa?
 em anexo vai o código completo, tem mais 2 separadores
Offline silva_p
Re:incompatibilidade de megaservo com wire?
« Responder #1 em: 19 de Maio de 2009, 14:24 »
então pessoal? ninguém me sabe ajudar? ???
« Responder #2 em: 19 de Maio de 2009, 14:35 »
O problema é que ambas as funções utilizam o watchdog 2 do atmega, e assim sendo, acabam por entrar em conflito pois este já está configurado com um timing, não pode ser modificado para outro.
O melhor é utilizar um outro atmega por Serial ou SPI, visto que não poderás implementar I2C nesse se utilizares o mega servo a controlar os servos... Entretanto se conseguir arranjar maneira de ficarem as duas a correr eu digo ;)
« Responder #3 em: 19 de Maio de 2009, 19:22 »
eu n sei qual é o funcionamento da megaservo.h, mas uma solução que te apresento, nem que seja apenas pra experimentares pôr isso a funcionar, é fazer o controlo directo por código (sem a ultilização da biblioteca de controlo dos servos) dos servos. é capaz até de nem ficar pior.
Offline silva_p
« Responder #4 em: 20 de Maio de 2009, 10:00 »
então e a servoTimer2?
tb usa o watchdog 2? :(
« Responder #5 em: 20 de Maio de 2009, 12:21 »
Sim silva, mas antes de avançarmos mais, testa fazer analogWrite para os pins que dizem PWM escrito, com a biblioteca wire em uso ao mesmo tempo, para vermos se assim serve.
