Sistemas específicos => Arduino / AVR => Tópico iniciado por: filmarvit em 08 de Novembro de 2011, 18:31
Estou a tentar comunicar com 2 arduinos utilizando o protoc Spi. quando tento enviar mais de 8 bits do lado do Master tudo seguido eu nao consigo tenho de fazer um delay entre cada transmissao.. Depois quando o slave responde ao Master a um pedido do lado do Master nao esta a receber nada nao sei se tenho de por o Slave em modo de Master?
code Master
#include <avr/io.h>
#include <util/delay.h> // delay eg _delay_ms(6);
#include <stdio.h>
void setup()
Serial.begin(9600);
/* SETTING CLOCK PRESCALER TO 1 */
CLKPR = 0x80; // Enable change to prescaler
CLKPR = 0x00; // Set clock prescaler to 1
/* SETTING UP PORT DIRECTIONS */
DDRB = 0b11101111; // All output except MISO (PB4)
/* SETTING UP SPI */
SPCR = 0x50; // Enable SPI in MSB-first mode, disable SPI interrupt and set SPI clock prescaler to 4
// SPSR |= 0x01; // Enable double speed (f_spi-clk = f_clk/2)
SPSR &= 0xFE; // Disable double speed
void SPI_MasterTransmit(unsigned char data_byte)
SPDR = data_byte;
PORTB &= 0xFB; // Pull SS low to enable the slave
while(!(SPSR & (1<<SPIF)));
PORTB |= 0x04; // Pull SS high to disable the slave
void loop()
int data;
//setup(); // Set registers for interrupts to run etc
delay(5000);
SPI_MasterTransmit('l');
delay(10);
SPI_MasterTransmit('c');
SPI_MasterTransmit('d');
data= SPI_SlaveReceive();
Serial.println(data);
unsigned char SPI_SlaveReceive()
return SPDR;
code Slave
#include <stdio.h>
#include <avr/io.h>
#include <SPI.h>
#define MOSI 11
#define MISO 12
#define SCK 13
#define SS 10
int array [3];
int array2[] = {108,99,100};
unsigned char data = 2;
unsigned char scrap;
int counter = 0;
void setup()
int i=0;
pinMode(MOSI, INPUT);
pinMode(MISO, OUTPUT);
pinMode(SCK,INPUT);
pinMode(SS,INPUT);
SPI.begin();
Serial.begin(9600);
Serial.println("Enabling SPI in slave mode");
SPCR = 0x40; // Enable SPI in slave mode
delay(500);
Serial.println("Initialisation complete.");
for(i=0;i<3;i++){
array= SPI_SlaveReceive();
Serial.println(array);
//Serial.println(data);
int i;
void loop()
int da;
/*i++;
data=0;
Serial.print("loop");
Serial.println(i);
data = SPI_SlaveReceive();
for(i=0;i<11;i++){
da=array;
Serial.println(data,DEC);
delay(1000);
if (array_cmp(array, array2, 3, 3) == true){
// do this if they are equal
da=5;
digitalWrite(SS,LOW);
SPI.transfer(da);
digitalWrite(SS,HIGH);
Serial.println("Entrou7777777");
Serial.println(da,HEX);
}else{
// do this if they are different
return SPDR;
void SPI_SlaveTransmit(unsigned char data_byte)
SPDR = data_byte;
boolean array_cmp(int *a, int *b, int len_a, int len_b){
int n;
Serial.println("Entrou");
// if their lengths are different, return false
if (len_a != len_b) return false;
// test each element to be the same. if not, return false
for (n=0;n<len_a;n++) if (a[n]!=b[n]) return false;
//ok, if we have not returned yet, they are equal :)
return true;
