Autor Tópico: Duvida no codigo  (Lida 4764 vezes)
Offline DFC17
Duvida no codigo
« em: 09 de Setembro de 2012, 15:12 »
Boas sou um principiante no codigo de arduino, e tenho uma duvida que espero que alguem me consiga ajudar, o codigo e o seguinte:
t dataIn = 'S';        //Character/Data coming from the phone.
int tras = 11;     //Pin that controls the car's Forward-Back motor.
int direita = 12;       //Pin that controls the car's Left-Right motor.
int frente = 13;  //Pin that enables/disables Left-Right motor.
int esquerda = 3;    //Pin that sets the speed for the Left-Right motor.
int luzes1 = 4;    //Pin that activates the Front lights.
int luzes2 = 7;    //Pin that activates the Back lights.
int determinant;         //Used in the check function, stores the character received from the phone.
int det;                 //Used in the loop function, stores the character received from the phone.
int velocity = 0;
void setup()
//*************NOTE: If using Bluetooth Mate Silver use 115200 btu
//                   If using MDFLY Bluetooth Module use 9600 btu
Serial.begin(115200);  //Initialize serial communication with Bluetooth module at 115200 btu.
pinMode(frente, OUTPUT);
pinMode(tras, OUTPUT);
pinMode(direita, OUTPUT);
pinMode(esquerda, OUTPUT);
pinMode(luzes1 , OUTPUT);
pinMode(luzes2 , OUTPUT);
void loop()
    det = check();
      while (det == 'F')   //if incoming data is a F, move forward
          digitalWrite(tras, HIGH);
          digitalWrite(esquerda, HIGH);
          digitalWrite(direita, HIGH);
          digitalWrite(frente, HIGH);
          det = check();
      while (det == 'B')   //if incoming data is a B, move back
          digitalWrite(direita, LOW);
          digitalWrite(frente, LOW);
          det = check();
      while (det == 'L')   //if incoming data is a L, move wheels left
          digitalWrite(tras, LOW);
          det = check();
      while (det == 'R')   //if incoming data is a R, move wheels right
          digitalWrite(esquerda, LOW);
          det = check();
      while (det == 'U')   //if incoming data is a U, turn ON front lights
          digitalWrite(luzes1, HIGH);
          det = check();
      while (det == 'u')   //if incoming data is a u, turn OFF front lights
          digitalWrite(luzes1, LOW);
          det = check();
      while (det == 'W')   //if incoming data is a W, turn ON back lights
          digitalWrite(luzes2, HIGH);
          det = check();
      while (det == 'w')   //if incoming data is a w, turn OFF back lights
          digitalWrite(luzes2, LOW);
          det = check();
int check()
  if (Serial.available() > 0)    //Check for data on the serial lines.
    dataIn = Serial.read();  //Get the character sent by the phone and store it in 'dataIn'.
        if (dataIn == 'F')
          determinant = 'F';
        else if (dataIn == 'B')
          determinant = 'B';
        else if (dataIn == 'L')
          determinant = 'L';
        else if (dataIn == 'R')
          determinant = 'R';
        else if (dataIn == 'S')
          determinant = 'S';
        else if (dataIn == 'U')
          determinant = 'U';
        else if (dataIn == 'u')
          determinant = 'u';
        else if (dataIn == 'W')
          determinant = 'W';
        else if (dataIn == 'w')
          determinant = 'w';
return determinant;
}/quote]
consiste num carro de dois motores controlado por um telemovel android atraves de bluetooth, onde recebe os dados e o ardumoto faz andar os motores, ele funciona bem, o problema e que quero que so ande enquanto primo o botao no android, como posso fazer isso no codigo? Este codigo foi reestruturado de um outro codigo...
Offline LuísR.A.
    • Clube de Robotica
Re: Duvida no codigo
« Responder #1 em: 09 de Setembro de 2012, 15:26 »
acho que se for algo simples como ligar e desligar podes usar um loop como "do...while"
enquanto o botão tiver ativado então os motores andam, caso contrario não andam
Tiva MCU é que é.
Offline andlig
« Responder #2 em: 09 de Setembro de 2012, 15:34 »
luis RA consegues-me ajudar em relacao ao topico com o nome problema com arduino??
muito obrigado, era muito importante se nao conseguir nao posso continuar com o projecto ja tem la o esquema que estou a usar se poder experimentar agradecia
mais uma vez muito obrigado
em relacao a este problema infelizmente nao posso ajudar tb sou um novato nisto de programacao
Offline DFC17
« Responder #3 em: 09 de Setembro de 2012, 15:50 »
podes dar me um exemplo para um botao, por exemplo quando ele recebe o "F" para andar para a frente?? e que nao percebi muito bem
Offline LuísR.A.
    • Clube de Robotica
« Responder #4 em: 09 de Setembro de 2012, 17:56 »
nao te sei dizer muito bem com o android mas seria algo assim
Do
}while (dataIn = 'F');
metes nesse loop o que queres que faça enquanto dataIn=F. Caso não seja F ele devera sair do loop
Tiva MCU é que é.
Offline Pedrock
« Responder #5 em: 09 de Setembro de 2012, 18:41 »
Do
Isso não resulta.
DFC17,
Não precisas usar while's. Podes usar apenas if's. Para parar, podes enviar uma mensagem para parar do Android, ou parar quando não recebe nenhuma mensagem do Android há algum tempo.
Offline Pedrock
« Responder #6 em: 09 de Setembro de 2012, 18:59 »
Editei o código:
int dataIn = 'S';        //Character/Data coming from the phone.
int velocity = 0;
unsigned long tempo = 0;
void setup()
void loop()
    det = check();
      if (det == 'F')   //if incoming data is a F, move forward
      else if(det == 'B')   //if incoming data is a B, move back
      else if (det == 'L')   //if incoming data is a L, move wheels left
      else if (det == 'R') //if incoming data is a R, move wheels right
      else if (det == 'P') Parar();
      else if (det == 'U')   //if incoming data is a U, turn ON front lights
      else if (det == 'u')   //if incoming data is a u, turn OFF front lights
      else if (det == 'W')   //if incoming data is a W, turn ON back lights
      else if (det == 'w')   //if incoming data is a w, turn OFF back lights
          digitalWrite(luzes2, LOW);'
      if ((millis()-tempo)>500)
      {Parar(); det == 'P';}
void Parar()
int check()
        if (dataIn == 'F')
          determinant = 'F';
          tempo = millis();
          determinant = 'B';
          tempo = millis();
          determinant = 'L';
          tempo = millis();
          determinant = 'R';
          tempo = millis();
          determinant = 'S';
          determinant = 'U';
          determinant = 'u';
          determinant = 'W';
          determinant = 'w';
return determinant;
O código para parar é este?:
Offline DFC17
« Responder #7 em: 09 de Setembro de 2012, 19:28 »
sim e, mas tambem nao pode ter os tempos, ja experimentei e o meu robo so anda meio segundo de cada vez, tenho de voltar a carregar no botao para ele voltar a andar mais meio segundo, obrigado na mesma :)
Offline Pedrock
« Responder #8 em: 09 de Setembro de 2012, 19:43 »
O código do Arduino está correcto então.
Tu é que fizeste a app para android? Tens que fazer com que a app envie o sinal para andar várias vezes e não apenas uma quando clicas no botão. E quando largares o botão pode enviar um 'P' para parar imediatamente.
Offline DFC17
« Responder #9 em: 09 de Setembro de 2012, 19:48 »
Obrigado a todos ja descobri o problema :P ja ta resolvido :) fica aqui o codigo a quem quiser brincar com o programa android bluetooth RC disponivel no android market :)
Este codigo apenas funciona para controlar 2 motores e leds :)
int velocity = 0;
void setup()
void loop()
    det = check();
          det = check();
          det = check();
          det = check();
          det = check();
      while (det == 'S')   //if incoming data is a I, turn right forward
          det = check();
          det = check();
          det = check();
          det = check();
          det = check();
int check()
        if (dataIn == 'F')
          determinant = 'F';
          determinant = 'B';
          determinant = 'L';
          determinant = 'R';
          determinant = 'S';
          determinant = 'U';
          determinant = 'u';
          determinant = 'W';
          determinant = 'w';
return determinant;
