Ajuda a programar arduino
Started by The Wolfman, 28 de April de 2010, 14:39
The Wolfman
Olá, boa tarde.
Tenho o seguinte material:
3* Devantech SRF05
2* Mini metal Gear motor
1* SN754410
1* LDR (embora ache que está mal feito).
Tenho de fazer com que o meu robot ande e se desvie de obstáculos, e depois quando encontrar uma certa cor, ele vai acender um LED.
Podem ajudar-me? É que eu sou mesmo muito mau em C, comecei a poucos dias :p
Encontrei isto na net, e consegui por a funcionar:
// written at: luckylarry.co.uk
// variables to take x number of readings and then average them
// to remove the jitter/noise from the SRF05 sonar readings
const int numOfReadings = 10; // number of readings to take/ items in the array
int readings[numOfReadings];    // stores the distance readings in an array
int arrayIndex = 0;              // arrayIndex of the current item in the array
int total = 0;                  // stores the cumlative total
int averageDistance = 0;        // stores the average value
// setup pins and variables for SRF05 sonar device
int echoPin = 2;              // SRF05 echo pin (digital 2)
int initPin = 3;              // SRF05 trigger pin (digital 3)
unsigned long pulseTime = 0;  // stores the pulse in Micro Seconds
unsigned long distance = 0;  // variable for storing the distance (cm)
// setup pins/values for LED
int redLEDPin = 9;    // Red LED, connected to digital PWM pin 9
int redLEDValue = 0; // stores the value of brightness for the LED (0 = fully off, 255 = fully on)
//setup
void setup() {
  pinMode(redLEDPin, OUTPUT);    // sets pin 9 as output
  pinMode(initPin, OUTPUT); // set init pin 3 as output
  pinMode(echoPin, INPUT); // set echo pin 2 as input
  // create array loop to iterate over every item in the array
  for (int thisReading = 0; thisReading < numOfReadings; thisReading++) {
readings[thisReading] = 0;
// initialize the serial port, lets you view the
// distances being pinged if connected to computer
     Serial.begin(9600);
// execute
void loop() {
digitalWrite(initPin, HIGH);   // send 10 microsecond pulse
delayMicroseconds(10);   // wait 10 microseconds before turning off
digitalWrite(initPin, LOW); // stop sending the pulse
pulseTime = pulseIn(echoPin, HIGH); // Look for a return pulse, it should be high as the pulse goes low-high-low
distance = pulseTime/58;   // Distance = pulse time / 58 to convert to cm.
total= total - readings[arrayIndex]; // subtract the last distance
readings[arrayIndex] = distance; // add distance reading to array
total= total + readings[arrayIndex]; // add the reading to the total
arrayIndex = arrayIndex + 1;          // go to the next item in the array
// At the end of the array (10 items) then start again
if (arrayIndex >= numOfReadings)  {
    arrayIndex = 0;
  averageDistance = total / numOfReadings;  // calculate the average distance
  // if the distance is less than 255cm then change the brightness of the LED
  if (averageDistance < 255) {
    redLEDValue = 255 - averageDistance; // this means the smaller the distance the brighterthe LED.
  analogWrite(redLEDPin, redLEDValue); // Write current value to LED pins
  Serial.println(averageDistance, DEC); // print out the average distance to the debugger
  delay(100);   // wait 100 milli seconds before looping again
Alguém me pode dar uma ajuda, ou uns tutoriais que encontrem? Não encontrei nada de um LDR com o arduino.
The Wolfman
#1
O que é que este código tem de mal?
Este fui eu que fiz, seguindo o exemplo do site do arduino, mas depois adaptei os valores ao devantech srf05.
const int sens = 7;
void setup () {
  Serial.begin(9600);
void loop()
  pinMode (sens, OUTPUT);
  digitalWrite (sens, LOW);
  delayMicroseconds (2);
  digitalWrite (sens, HIGH);
  delayMicroseconds (5);
  duration = pulseIn(sens, HIGH);
  cm = microsecondsToCentimeters(duration);
  Serial.print(cm);
  Serial.print("cm");
  Serial.printIn();
  delay(100);
long microsecondsToCentimeters(long microseconds)
  return microseconds / 29
Quando vai a compilar, dá o seguinte erro:
QuoteIn function 'void loop()':
error: 'duration' was not declared in this scope In function 'long int microsecondsToCentimeters(long int)':
Qual é o problema? Segui o que estava aqui à risca, só usei centímetros em vez de polegadas...
http://arduino.cc/en/Tutorial/Ping
TigPT
#2
Quotelong microsecondsToCentimeters(long microseconds)
Estás a chamar a função que ele ainda não conhece.
Todas as funções têm que estar definidas antes da sua chamada. Basta meter essa função antes do loop e já deve de funcionar.
_________
A variável "cm" também não está declarada. (não sei se o arduino permite a tal história a cima referida visto poder estar protegido contra erros de iniciantes e fazer automaticamente a declaração da função abaixo definida.
The Wolfman
Então e em que sitio é que eu tenho de colocar isto?
Suponho que seja ''dentro'' desta coisa do void loop...
TigPT
cm = microsecondsToCentimeters(duration); passa a ser:
long cm = microsecondsToCentimeters(duration);
Ou então no ínicio do código onde tens:
const int sens = 7;
Metes por baixo:
long cm;
The Wolfman
Continua a dar erro, e experimentei das duas maneiras...
TigPT
Tinhas inúmeros erros desde chavetas a pontos e virgulas ou até declaração das variáveis.
Corrigido:
const int sens = 7;
void setup () {
  Serial.begin(9600);
void loop()
  long duration = pulseIn(sens, HIGH);
  Serial.print(cm);
  Serial.print("cm");
  Serial.println();
  delay(100);
  return microseconds / 29;
The Wolfman
Assim já funciona, mas o raio do código dá-me no ''debug'' 0cm, e a luz do sensor pisca muito devagar...
TigPT
Não vi código.. só corrigi sintax.
The Wolfman
#9
Bem, usei os exemplos do arduino.cc, mas parece que aquilo só servia para o PING))) da paralaxx.
Então pesquisei no google, e enconrei um código para o devantech srf05. Configurei aquilo para 3 sensores, e funcionou :D
Mas só postei hoje porque o meu irmão desligou o computador e não tinha gravado o código :p
Aqui está:
int duration_frt;
int distance_frt;
int srf_frt = 4;
int duration_esq;
int distance_esq;
int srf_esq = 5;
int duration_dir;
int distance_dir;
int srf_dir = 6;
void setup(){
Serial.begin(9600);
void loop(){
  pinMode(srf_frt, OUTPUT);
  digitalWrite(srf_frt, LOW);
  delayMicroseconds(2);
  digitalWrite(srf_frt, HIGH);
  pinMode(srf_frt, INPUT);
  duration_frt = pulseIn(srf_frt, HIGH);
  distance_frt = duration_frt/58;
  pinMode(srf_esq, OUTPUT);
  digitalWrite(srf_esq, LOW);
  digitalWrite(srf_esq, HIGH);
  pinMode(srf_esq, INPUT);
  duration_esq = pulseIn(srf_esq, HIGH);
  distance_esq = duration_esq/58;
  pinMode(srf_dir, OUTPUT);
  digitalWrite(srf_dir, LOW);
  digitalWrite(srf_dir, HIGH);
  pinMode(srf_dir, INPUT);
  duration_dir = pulseIn(srf_dir, HIGH);
  distance_dir = duration_dir/58;
  Serial.println(distance_frt);
  delay(100);
O que acham?
Falta-me agora configurar os motores com a ponte-H, o LDR e o LED para quando encontrar uma vitima.
The Wolfman
#10
Bem, o LDR já está também...
Neste momento tenho o arduino ligado por USB, mas vou usar 8 pilhas de NiCd.
O LDR tem dois LED's de cada lado para ele ''ver'' melhor, e como esses LED's estão ligados em série, 5V, eles têm uma luz muito fraquinha.
Neste código, defini o pino 13 como saida, e acendi os LED's, mas 5V para dois led's é pouco, pelo que no código final, vou apagar esta parte, e ligar os LED's directamente ao Vin
int duration_frt;
int distance_frt;
int srf_frt = 4;
int duration_esq;
int distance_esq;
int srf_esq = 5;
int duration_dir;
int distance_dir;
int srf_dir = 6;
int ldr = 0;
int valor_ldr = 5;
int led_ldr = 13;
void setup(){
Serial.begin(9600);
void loop(){
  ldr = analogRead(valor_ldr);
  digitalWrite(led_ldr, HIGH);
  Serial.println(ldr);
  delay(100);
Agora vou tratar da ponte H, mas tenho de ver se me safo nas sub-rotinas para depois decidir para que lado anda o bixo.
The Wolfman
#11
Ora bem, inclui aqui uma parte dos motores.
int duration_frt;
int distance_frt;
int srf_frt = 4;
int duration_esq;
int distance_esq;
int srf_esq = 5;
int duration_dir;
int distance_dir;
int srf_dir = 6;
int ldr = 0;
int valor_ldr = 5;
int led_ldr = 13;
int motor_esq[] = {2, 3};
int motor_dir[] = {7,8};
int i;
void setup(){
Serial.begin(9600);
for(i = 0; i < 2; i++){
  pinMode(motor_esq[i], OUTPUT);
  pinMode(motor_dir[i], OUTPUT);
void loop(){
  digitalWrite(motor_esq[0], HIGH);
  digitalWrite(motor_esq[1], LOW);
  digitalWrite(motor_dir[0], HIGH);
  digitalWrite(motor_dir[1], LOW);
  delay(100);
Não os posso ligar porque tenho o arduino ligado por USB, mas isto assim não devia dar 5V nos fios que ligam aos motores? Se eu for medir com o multimetro a tensão nos fios que supostamente ligam nos motores, tenho uma tensão de 0,284V...
The Wolfman
Bem, por hoje não faço mais nada.
Já adicionei um LED com o comando if (fui ver ao site do arduino como funciona).
Se o valor do LDR for maior que 500 acende, se não for apaga. O que achei estranho foi ter de dizer que se o valor for menor, o led fica LOW, não é lógico?
int duration_frt;
int distance_frt;
int srf_frt = 4;
int duration_esq;
int distance_esq;
int srf_esq = 5;
int duration_dir;
int distance_dir;
int srf_dir = 6;
int ldr = 0;
int valor_ldr = 5;
int led_ldr = 13;
int i;
int led_vitima = 12;
void setup(){
Serial.begin(9600);
void loop(){
  if (ldr > 500)
  pinMode(led_vitima, OUTPUT);
  digitalWrite(led_vitima, HIGH);
  if (ldr < 500)
  digitalWrite(led_vitima, LOW);
  delay(100);
E pronto, as minhas brincadeiras de hoje acabaram, comentem :D
P.S., TigPT, reparei agora que nestes casos mete-se as tags code e não quote, já não precisas de ter trabalho ;)
TigPT
Até amanha. Não tenhas pesadelos com código. Vai lá com o tempo. ;)
The Wolfman
Oh pá, as vezes sou mesmo estúpido. Tive dois dias a pensar porque é que a ponte H não funciona, e só hoje é que vi que não a liguei ao ground --'
Já está a funcionar, e já ando a tratar de sub rotinas.
