Arduíno e protocolo SPI
Started by filmarvit, 08 de November de 2011, 18:31
filmarvit
Estou a tentar comunicar com 2 arduinos  utilizando  o protoc Spi. quando tento enviar mais de 8 bits do lado do Master tudo seguido eu nao consigo tenho de fazer um delay entre cada transmissao.. Depois quando o slave responde ao Master a um pedido do lado do Master nao esta a receber nada nao sei se tenho de por o Slave em modo de Master?
code  Master
#include <avr/io.h>
#include <util/delay.h>   // delay eg _delay_ms(6);
#include <stdio.h>
void setup()
   Serial.begin(9600);
   /* SETTING CLOCK PRESCALER TO 1 */
   CLKPR = 0x80;    // Enable change to prescaler
   CLKPR = 0x00;    // Set clock prescaler to 1
   /* SETTING UP PORT DIRECTIONS */
   DDRB = 0b11101111;   // All output except MISO (PB4)
   /* SETTING UP SPI */
   SPCR = 0x50;   // Enable SPI in MSB-first mode, disable SPI interrupt and set SPI clock prescaler to 4
//   SPSR |= 0x01;   // Enable double speed (f_spi-clk = f_clk/2)
   SPSR &= 0xFE;   // Disable double speed
void SPI_MasterTransmit(unsigned char data_byte)
   SPDR = data_byte;
   PORTB &= 0xFB;   // Pull SS low to enable the slave
   while(!(SPSR & (1<<SPIF)));
   PORTB |= 0x04;   // Pull SS high to disable the slave
void loop()
  int data;
   //setup();   // Set registers for interrupts to run etc
   delay(5000);
   SPI_MasterTransmit('l');
    delay(10);
   SPI_MasterTransmit('c');
   SPI_MasterTransmit('d');
   data= SPI_SlaveReceive();
  Serial.println(data);
unsigned char SPI_SlaveReceive()
  return SPDR;
code Slave
#include <stdio.h>
#include <avr/io.h>
#include <SPI.h>
#define MOSI 11
#define MISO  12
#define SCK  13
#define SS 10
int array [3];
int array2[] = {108,99,100};
unsigned char data = 2;
unsigned char scrap;
int counter = 0;
void setup()
  int i=0;
  pinMode(MOSI, INPUT);
  pinMode(MISO, OUTPUT);
  pinMode(SCK,INPUT);
  pinMode(SS,INPUT);
  SPI.begin();
  Serial.begin(9600);
  Serial.println("Enabling SPI in slave mode");
  SPCR = 0x40;  // Enable SPI in slave mode
  delay(500);
  Serial.println("Initialisation complete.");
  for(i=0;i<3;i++){
  array= SPI_SlaveReceive();
   Serial.println(array);
  //Serial.println(data);
int i;
void loop()
int  da;
  /*i++;
  data=0;
  Serial.print("loop");
  Serial.println(i);
  data = SPI_SlaveReceive();
for(i=0;i<11;i++){
da=array;
Serial.println(data,DEC);
delay(1000);
if (array_cmp(array, array2, 3, 3) == true){
   // do this if they are equal
   da=5;
   digitalWrite(SS,LOW);
   SPI.transfer(da);
   digitalWrite(SS,HIGH);
      Serial.println("Entrou7777777");
       Serial.println(da,HEX);
   }else{
      // do this if they are different
  return SPDR;
void SPI_SlaveTransmit(unsigned char data_byte)
   SPDR = data_byte;
boolean array_cmp(int *a, int *b, int len_a, int len_b){
   int n;
          Serial.println("Entrou");
   // if their lengths are different, return false
   if (len_a != len_b) return false;
   // test each element to be the same. if not, return false
   for (n=0;n<len_a;n++) if (a[n]!=b[n]) return false;
   //ok, if we have not returned yet, they are equal :)
   return true;
