[Ontem às 14:14]
Autor Tópico: Sensor de temp dois arduinos, do quarto para a sala via RF  (Lida 49794 vezes)
Offline rglove
Re: Sensor de temp dois arduinos, do quarto para a sala via RF
« Responder #120 em: 06 de Setembro de 2012, 21:25 »
Mudaste no código os pinos que trocaste?
Offline r16
« Responder #121 em: 06 de Setembro de 2012, 21:42 »
sim , de momento tenho
  LiquidCrystal Library - Hello World
 Demonstrates the use a 16x2 LCD display.  The LiquidCrystal
 library works with all LCD displays that are compatible with the
 Hitachi HD44780 driver. There are many of them out there, and you
 can usually tell them by the 16-pin interface.
 This sketch prints "Hello World!" to the LCD
 and shows the time.
  The circuit:
 * LCD RS pin to digital pin 12
 * LCD Enable pin to digital pin 11 // liguei ao 10
 * LCD D4 pin to digital pin 5
 * LCD D5 pin to digital pin 4
 * LCD D6 pin to digital pin 3
 * LCD D7 pin to digital pin 2
 * LCD R/W pin to ground // liguei a 11
 * 10K resistor: (nao sei)
 * ends to +5V and ground (nao sei)
 * wiper to LCD VO pin (pin 3) // liguei ao 8 que que utilizei como pin
 pwr para o contraste.
 Library originally added 18 Apr 2008
 by David A. Mellis
 library modified 5 Jul 2009
 by Limor Fried (http://www.ladyada.net)
 example added 9 Jul 2009
 by Tom Igoe
 modified 22 Nov 2010
 by Tom Igoe
 This example code is in the public domain.
 http://www.arduino.cc/en/Tutorial/LiquidCrystal
// include the library code:
#include <LiquidCrystal.h>
int ledPin = 8;
// initialize the library with the numbers of the interface pins
LiquidCrystal lcd(12, 10, 5, 4, 3, 2);
void setup() {
   pinMode(ledPin, OUTPUT);
  // set up the LCD's number of columns and rows:
  lcd.begin(16, 2);
  // Print a message to the LCD.
  lcd.print("hello, world!");
void loop() {
  analogWrite(ledPin, 60);
  // set the cursor to column 0, line 1
  // (note: line 1 is the second row, since counting begins with 0):
  lcd.setCursor(0, 1);
  // print the number of seconds since reset:
 lcd.print(millis()/1000);
a unica palavra de jeito que se le é world!
de resto e so numeros e cardinais..
se esconder o
ja aparece hello world como deve ser
Offline rglove
« Responder #122 em: 06 de Setembro de 2012, 21:50 »
Ligaste o R/W ao ground?
Esses caracteres só aparecem a partir da segunda vez que escreves no lcd, portanto esse "hello world" sem o millis() funciona porque o "hello world" só é escrito uma vez no lcd...
Offline r16
« Responder #123 em: 06 de Setembro de 2012, 21:52 »
sim liguei, sera o lcd que nao ta em condicoes??
Offline Pedrock
« Responder #124 em: 06 de Setembro de 2012, 22:16 »
Desliga tudo o arduino e faz isto:
http://arduino.cc/en/Tutorial/LiquidCrystal
Usa os pinos que eles usam e como não tens um potenciómetro, usa resistências.
« Última modificação: 06 de Setembro de 2012, 22:19 por Pedrock »
Offline r16
« Responder #125 em: 06 de Setembro de 2012, 22:22 »
se tiver que usar so uma resistencia qual e o valor dela? ligo de onde  a onde?
se for duas qual o valor de cada?
Offline Pedrock
« Responder #126 em: 06 de Setembro de 2012, 22:35 »
Liga uma resistência entre Vcc e Vc com um valor entre 0 e 10k, tens que ver o que te dá um bom contraste.
Offline r16
« Responder #127 em: 06 de Setembro de 2012, 22:38 »
sim mas depois o pino VO vai ligar a onde, se tivesse um potenciometro ligava na perna do meio... mas assim liga onde?
« Responder #128 em: 06 de Setembro de 2012, 22:46 »
Ligas uma pata da resistência aos 5v e a outra ao VO, e depois ligas a pata de outra resistencia tambem ao VO e a segunda pata á massa, para fazer um dividor de tensão resistivo que é o que o potênciometro faz, usa um par de resistencias de 3 ou 4k.
Offline r16
« Responder #129 em: 06 de Setembro de 2012, 23:14 »
nao tenho esses valores de resistencia aqui, mas amanha vou comprar um potenciometro de 10k para tirar as teimas..
mas eu duvido que seja isso que me esta a fazer mostrar os caracteres malucos,. nao sei ate que ponto o contraste tem a ver com isto, visto que o resto das letras aparecem bem.
Offline Pedrock
« Responder #130 em: 06 de Setembro de 2012, 23:27 »
Se tiveres de 1k, por exemplo, podes juntar várias em série.
Offline r16
« Responder #131 em: 06 de Setembro de 2012, 23:35 »
so tenho aqui de valores altos... eu amanha vou comprar a porcaria do potenciometro para tirar as teimas..
eu nao entendo nada disto, mas tame a fazer especie..como é que um pino pwr não consegue fazer o mesmo trabalho que o potenciometro,,,e como é que o pino pwr é o causador dos caracteres estranhos.
Mas deixem tar que amanha, as duvidas sao tiradas.
Se alguem tiver ai um lcd que consiga testar era trabalho poupado.
Offline Pedrock
« Responder #132 em: 06 de Setembro de 2012, 23:42 »
Eu também não acho que seja disso. Mas o PWM não é a mesma coisa que usar o potenciómetro.
O problema não está no código, tem que estar no LCD, no Arduino ou nas ligações.
Offline r16
« Responder #133 em: 07 de Setembro de 2012, 22:07 »
bom teimoso que é teimoso não descansa....
hoje fui comprar a porcaria do potenciometro a ver se o problema era então esse, visto que o PWR para algumas pessoas não seria o causador,,, mas para outra suscitava dúvidas...
Liguei e Funciona.....era mesmo do PWR
Agora vou testar o codigo da temperatura humidade postado há alguns posts atrás.
Offline Pedrock
« Responder #134 em: 07 de Setembro de 2012, 22:11 »
Então ainda bem que era disso, assim ficou resolvido.
Agora o código deve funcionar sem grandes problemas.
