Autor Tópico: Vendo modulo Bluetooth  (Lida 4450 vezes)
Offline camolas
« em: 15 de Janeiro de 2013, 23:50 »
Tenho para venda 1 modulo Bluetooth para arduino, pic, arm...
Preço 13€ portes incluidos.
Specs:
Bluetooth Transceiver Module RS232 / TTL HC-05
Suitable for Bluetooth adapter, Bluetooth phone use, master-slave can also be used in double.
Can be set for the module control parameters and control commands issued via AT commands.
Provide 7 input and output ports, scalable user IO resources.
Work status indicators; connection with the non-connection state signal output, easy to track the status of module MCU.
Great for embedded wireless serial transmission alternatives.
Bluetooth Specification v2.0+EDR.
USB protocol: USB v1.1/2.0.
Frequency: 2.4GHz ISM band.
Modulation: GFSK(Gaussian Frequency Shift Keying).
Transmit power: not more than 4dBm, Class 2.
Sensitivity: not more than -84dBm at 0.1% BER.
Rate: Asynchronous: 2.1Mbps(Max) / 160 kbps.
Synchronous: 1Mbps/1Mbps.
Security features: Authentication and encryption.
Support profiles: Bluetooth serial port (master & slave).
Power Supply: +3.3VDC 50mA.
Working temperature: ?5°C to 45°C.
Max. serial baud rate: 1382400bps, support for hardware flow control transfer.
Size:2.7cm x 1.3cm - 1.06inch x 0.51inch.
Obg.
« Última modificação: 20 de Janeiro de 2013, 22:12 por camolas »
Re: Vendo modulo Bluetooth
« Responder #1 em: 16 de Janeiro de 2013, 00:13 »
Especificações e documentação disso, podes por?
Vai ajudar a venderes isso mais facilmente ;)
Offline pmj_pedro
« Responder #2 em: 16 de Janeiro de 2013, 00:37 »
acho que a esse preço vai ser dificil de venderes o modulo
Offline camolas
« Responder #3 em: 16 de Janeiro de 2013, 16:30 »
Tem portes incluidos (2.5€ sensivelmente em cr) fica 10.5€ para o modulo e caro?
Obg
Paulo
Offline TheDeadLives
« Responder #4 em: 16 de Janeiro de 2013, 22:41 »
Offline camolas
« Responder #6 em: 16 de Janeiro de 2013, 23:02 »
Depende de á quanto tempo o compraste.
« Responder #7 em: 17 de Janeiro de 2013, 17:30 »
Eu até estava interessado mas como não colocaste informação nenhuma sobre o modulo, como te tinha pedido, já perdeste uma oportunidade de vender isso.
« Responder #8 em: 17 de Janeiro de 2013, 20:52 »
basta pesquisares na net!  8)
Offline camolas
« Responder #9 em: 17 de Janeiro de 2013, 21:47 »
Por falta de tempo não coloquei as specs ontem mas hoje já estão.
obg.
