Autor Tópico: ServoTimer2 ??? isto não cheira bem...  (Lida 20702 vezes)
Re:ServoTimer2 ??? isto não cheira bem...
« Responder #15 em: 02 de Abril de 2009, 22:15 »
never mind lol xD encontrei uma biblioteca que dá para controlar 12 servos com o duemillanove, e 45 com o arduino mega!!!
http://www.arduino.cc/playground/Code/MegaServo
para quem quiser dar uma vista de olhos, e n consegui instalar o servotimer2... n sei porque... esta foi logo...
« Responder #16 em: 02 de Abril de 2009, 23:39 »
Obrigado por partilhares, pode dar jeito ;)
Offline silva_p
ServoTimer2 briga com wire?
« Responder #17 em: 12 de Abril de 2009, 22:46 »
estou a usar a biblioteca servotimer2 para controlar 4 servos e até ai td bem, agora quando junto a nunchuk dá isto :
hardware\libraries\Wire/Wire.h: In function 'void loop()':
hardware\libraries\Wire/Wire.h:30: error: local class 'class loop()::TwoWire' shall not have static data member 'uint8_t* loop()::TwoWire::rxBuffer'
hardware\libraries\Wire/Wire.h:31: error: local class 'class loop()::TwoWire' shall not have static data member 'uint8_t loop()::TwoWire::rxBufferIndex'
hardware\libraries\Wire/Wire.h:32: error: local class 'class loop()::TwoWire' shall not have static data member 'uint8_t loop()::TwoWire::rxBufferLength'
hardware\libraries\Wire/Wire.h:34: error: local class 'class loop()::TwoWire' shall not have static data member 'uint8_t loop()::TwoWire::txAddress'
hardware\libraries\Wire/Wire.h:35: error: local class 'class loop()::TwoWire' shall not have static data member 'uint8_t* loop()::TwoWire::txBuffer'
hardware\libraries\Wire/Wire.h:36: error: local class 'class loop()::TwoWire' shall not have static data member 'uint8_t loop()::TwoWire::txBufferIndex'
hardware\libraries\Wire/Wire.h:37: error: local class 'class loop()::TwoWire' shall not have static data member 'uint8_t loop()::TwoWire::txBufferLength'
hardware\libraries\Wire/Wire.h:39: error: local class 'class loop()::TwoWire' shall not have static data member 'uint8_t loop()::TwoWire::transmitting'
hardware\libraries\Wire/Wire.h:40: error: local class 'class loop()::TwoWire' shall not have static data member 'void (* loop()::TwoWire::user_onRequest)()'
hardware\libraries\Wire/Wire.h:41: error: local class 'class loop()::TwoWire' shall not have static data member 'void (* loop()::TwoWire::user_onReceive)(int)'
isot é acerca da biblioteca wire.h que é usada para lar os dados da nunchuk, será que as duas bibliotecas são incompativeis? a servotimer2 e a wire?
pk em separado ambas funcionam bem.
« Última modificação: 12 de Abril de 2009, 23:09 por TigPT »
« Responder #18 em: 13 de Abril de 2009, 10:16 »
aconselho
MegaServo, podes controlar servos em todos os pinos! e talvez seja compativel com a wire.
eu tenho por ai um link vou ver se encontro
