ADC de 50V vs Divisor de tensão em ADC de 5V
Started by LuísR.A., 03 de February de 2015, 23:09
Quote from: Njay on 04 de February de 2015, 00:18
Se tens 1 chip ADC com entrada directa de 50V e outro com entrada directa de 5V, a precisão só se pode comparar pegando nas 2 datasheets e no caso do ADC de 5V ter em conta a tolerância do divisor de tensão. Qualquer um dos esquemas pode ser mais preciso do que o outro, nada se pode concluir sem datasheet e análise concreta pois são 2 chips diferentes.
Continuando...
Se queres saber resolução, e assumindo que ambos os ADC têm a mesma resolução (contagens, ou bits), está tudo dito! Igual. No ADC que lê 50V directamente e tem 5000 contagens de resolução (log2(5000) bits) tens uma resolução de 10mV (50V / 5000) e no ADC de 5V com um divisor /10 à entrada tens 5V / 5000 x 10 = 10mV (Vadc = Vin / 10 => Vin = Vadc x 10: Vadc = 1mV => Vin = 1mV x 10 = 10mV).
Quote from: LuísR.A. on 03 de February de 2015, 23:41
Vou aqui a copiar a explicação, talvez consigam perceber melhor que eu:
QuoteLet's simplify to try and better explain our adversion to voltage dividers.  Assume we have an ADC with 5000 bits resolution and 5V max input.  (there are none - let's just agree)
Now - if we feed a 50V signal in - we must employ a 10:1 divider - right?  Thus - each "real signal" input gets divided by 10 - before it even reaches the ADC.  Thus a ONE Volt change in level is received at the ADC as (just) a 100mV level - isn't that so?
Now as we have 5000mV of signal span @ the ADC - and 5V as max input - that equates to 1mV/ADC reading - does it not?  Then - when we feed that ADC a 50V signal thru the same divider - it becomes 5V - which yields our desired 5000 ADC reading.  And - when we feed in a 49V signal - which is reduced to 4.9V by the divider - we measure (correctly) 4900 at the ADC.
But - we get into trouble when our input signal is 49,990 - 49,999mV - do we not?  The ADC will respond w/4999 or 5000 - it cannot resolve that mV signal level - as it's been lost in the voltage divider!   That is the "resultant imprecision" forced upon the ADC by the voltage divider, Luis!
A questão ainda é outra NJay, tudo isto advém de um erro cometido nesta cotação.
Com um ADC de 5 mil counts, e entrada de 50v cada LSB corresponde a 10mV!
Acho que esta confusão vem de quem escreveu isto "dar" uma resolução de 50 mil counts ao ADC de 50v e 5 mil counts ao ADC de 5v, obviamente que com mais um digito consegue medir mais uma casa decimal.
Ou seja, e repetindo o que já disse, se as ADC's tiverem a mesma resolução, o LSB acaba por dar no mesmo, a informação tem de ser a mesma, porque a resolução é a mesma, não tiras 5 digitos de uma ADC de 8 bits, e noutra adc tambem ela de 8 bits só tiras 4 digitos(valores exagerados para efeitos demonstrativos).
Certo. Como tu dizes, se o ADC que suporta entrada directa de 50V tiver mais resolução, claro que "é melhor" do que um ADC de menor resolução a ler os mesmos 50V, independentemente de ter ou não divisor de tensão.
Penso que essa noção de um "ADC de X ou Y volts" está a criar confusão e a induzir em erro
quem possa estar a ler, mas que raio é isso de um "ADC de 50V" ? ? ? Isso não é nenhuma
característica e não nos diz absolutamente nada. A única característica que importa é a
resolução em bits, para um mesmo ADC a resolução é SEMPRE a mesma qualquer que seja
a tensão analisada, o que pode variar é o LSB que reflecte o mínimo valor susceptível de ser
lido para uma determinada tensão.
Esse texto em inglês é um exemplo tipifico da desinformação que se pode por vezes encontrar
na net, e serve para confirmar que nem tudo o que vem à rede é peixe :)
Num ADC a unica coisa que importa é a resolução?
Sweet, nem sei porque é que não fazem osciloscópios com Arduinos  8)
Quote from: senso on 05 de February de 2015, 22:11
Sim, para o caso em questão, que outras características influenciam os ditos "counts" ?
(terminologia do autor do tal artigo, não minha)
E pois, acaso, mas mesmo só por acaso, até existem por ai uma dezenas de projectos
de "osciloscópio" com arduinos, e melhor ainda, existem osciloscópio para PC com entrada
pelo porta do microfone, é claro que não se podem comparar as funções destes scopes com
um equipamento especifico, mas tendo em conta os resultados faz pensar.
Faz uma procura no google e vais ver o que encontras.
Quote from: senso on 04 de February de 2015, 00:33
O LSB é o mesmo para a mesma Vref, mas uma vez que existe uma conversão pelo divisor de tensão
temos que incluir esse factor nas contas finais, o que na realidade vai alterar o LSB para diferentes
tensão a analisar ... pelo menos e com  essa premissa que sempre utilizei um ADC e a matemática
assim o prova.
Quote from: StarRider on 05 de February de 2015, 22:22
Ironia, passou-te ao lado.
Quote from: senso on 05 de February de 2015, 22:38
Yap ... passou mesmo, mas agora já apanhei, a PDI tem destas coisas ... sorry :(
"Counts", ou em Ptguês "contagens", é uma terminologia para resolução que já vi muito por aí, especialmente em equipamento como multimetros.
A parte da resolução/LSB's, não estava a meter referências ao barulho para não causar confusão, provavelmente foi uma má aposta por não ficar tudo claro.
Eu sei que há coisas dessas para mil e uma dev-boards, até podes correr o Demon Core do OLS num micro e fazer um mini logic analyzer com um Arduino, ou um MSP ou um STM, são coisas que em cima do joelho desenrascam e é melhor que nada.
Agora é esperar que o Kristey cá venha dar a sua opinião.
LuísR.A.
Quote from: senso on 06 de February de 2015, 09:05
Wat? XD
PS: Não tou a comentar porque sinceramente nem sei que dizer, eu concordo com o que têm dito sobre a resolução é que interessa para bem... a resolução neh? Não a referência, isto usando divisores de tensão para escalar as tensôes
Tiva MCU é que é.
LuísR.A.
Tiva MCU é que é.
