Autor Tópico: Erro na hora de fazer "Upload de programa para o Arduíno Uno"  (Lida 11367 vezes)
Offline megamartinelle
Bem pessoa, tem um erro que está acontecendo na hora de fazer um upload, ta com mais de uma semana que tento encontrar onde ta errado e nada. O código do programa é de uma CNC com Arduino. Vou disponibilizar o arquivo da programação e o erro que aparece.
Arquivo de se deve abrir é o que tem o nome de: reprap_new_firmware.ino
Erro que aparece:
reprap_new_firmware.ino: In function ‘void setup()’:
reprap_new_firmware.ino:27:17: error: ‘init_steppers’ was not declared in this scope
reprap_new_firmware.ino:30:27: error: ‘calculateAccelConstants’ was not declared in this scope
reprap_new_firmware.ino:31:15: error: ‘SetupTimer1’ was not declared in this scope
extruder.ino: In function ‘void init_extruder()’:
extruder.ino:39:104: error: ‘getRegAndBitmask’ was not declared in this scope
extruder.ino:40:88: error: ‘fastDigitalWrite’ was not declared in this scope
extruder.ino: In function ‘void extruder_set_direction(bool)’:
extruder.ino:49:81: error: ‘fastDigitalWrite’ was not declared in this scope
In file included from /usr/share/arduino/hardware/arduino/variants/standard/pins_arduino.h:28:0,
                 from reprap_new_firmware.h:1,
                 from reprap_new_firmware.ino:1:
process_string.ino: At global scope:
process_string.ino:44:29: error: variable ‘codeTypes’ must be const in order to be put into read-only section by means of ‘__attribute__((progmem))’
process_string.ino: In function ‘void process_string(char*, int)’:
process_string.ino:298:31: error: ‘calculateAccelConstants’ was not declared in this scope
process_string.ino:327:36: error: ‘calculate_deltas’ was not declared in this scope
process_string.ino:332:37: error: ‘advance_move_queue’ was not declared in this scope
process_string.ino:409:29: error: variable ‘octantTbl’ must be const in order to be put into read-only section by means of ‘__attribute__((progmem))’
Link do vídeo onde o homem mostra como configurar este programa:
Se for possível ajudar ficarei muito agradecido! :D
Offline ricard0g0mes
Re: Erro na hora de fazer "Upload de programa para o Arduíno Uno"
« Responder #1 em: 17 de Março de 2015, 19:37 »
boas.
copiaste a libraria para o directorio das librarias no arduino software?
« Responder #2 em: 17 de Março de 2015, 21:38 »
Eita poxa, esqueci desse detalhes. Muito obrigado amigo!
Mas, mesmo assim você poderia me dizer que libraria devo usar?
« Responder #3 em: 18 de Março de 2015, 10:22 »
<Grammar_Nazi>
    A tradução de "Library" é biblioteca.
    A tradução de livraria é "bookstore".
    Libraria é uma conjugação do verbo librar - 1ª ou 3ª pessoa do singular do condicional.
</Grammar_Nazi>
Offline fergas
« Responder #4 em: 18 de Março de 2015, 11:47 »
No zip que contém o código existem 2 dois ficheiros com a extensão *.h Experimenta colocar esses na pasta de bibliotecas do arduino e depois voltar a inciá-lo e ver qual o resultado.
« Responder #5 em: 19 de Março de 2015, 03:54 »
Deu certo, Obrigado mesmo!! :D
