Audio.h exemplo com erro no código
Started by megamartinelle, 11 de March de 2016, 20:28
megamartinelle
Olá pessoal, to fazendo um teste aqui com esse código:
#include <SD.h>
#include <SPI.h>
#include <Audio.h>
void setup() {
  // debug output at 9600 baud
  Serial.begin(9600);
  // setup SD-card
  Serial.print("Initializing SD card...");
  if (!SD.begin(4)) {
    Serial.println(" failed!");
    while(true);
  Serial.println(" done.");
  // hi-speed SPI transfers
  // 44100kHz stereo => 88200 sample rate
  // 100 mSec of prebuffering.
  Audio.begin(88200, 100);
void loop() {
  int count = 0;
  // open wave file from sdcard
  File myFile = SD.open("test.wav");
  if (!myFile) {
    // if the file didn't open, print an error and stop
    Serial.println("error opening test.wav");
    while (true);
  const int S = 1000; // Number of samples to read in block
  short buffer;
  Serial.print("Playing");
  // until the file is not finished
  while (myFile.available()) {
    // read from the file into buffer
    myFile.read(buffer, sizeof(buffer));
    // Prepare samples
    int volume = 1000;
    Audio.prepare(buffer, S, volume);
    // Feed samples to audio
    Audio.write(buffer, S);
    // Every 100 block print a '.'
    count++;
    if (count == 100) {
      Serial.print(".");
      count = 0;
  myFile.close();
  Serial.println("End of file. Thank you for listening!");
  while (true) ;
///////////E aparece esse erro quando vou compilar://////////////
Arduino: 1.6.7 (Windows 10), Placa:"Arduino/Genuino Uno"
AVISO: A categoria 'Education' na biblioteca EducationShield é invalida. Definindo para 'Uncategorized'
AVISO: a biblioteca Audio alega rodar em arquitetura(s) [sam] e pode ser incompatível com sua placa atual, que roda em arquitetura(s) [avr].
In file included from C:\Users\Bruno Martinelle\Documents\Arduino\libraries\Audio\src/Audio.h:16:0,
                 from C:\Users\BRUNOM~1\AppData\Local\Temp\arduino_aeda8030121f38bce14ed58c8df04f59\SimpleAudioPlayer.ino:3:
C:\Users\Bruno Martinelle\Documents\Arduino\libraries\Audio\src/DAC.h:21:16: error: expected ')' before '*' token
  DACClass(Dacc *_dac, uint32_t _dacId, IRQn_Type _isrId) :
C:\Users\Bruno Martinelle\Documents\Arduino\libraries\Audio\src/DAC.h:35:2: error: 'Dacc' does not name a type
  Dacc *dac;
C:\Users\Bruno Martinelle\Documents\Arduino\libraries\Audio\src/DAC.h:37:2: error: 'IRQn_Type' does not name a type
  IRQn_Type isrId;
C:\Users\Bruno Martinelle\Documents\Arduino\libraries\Audio\src/DAC.h: In member function 'void DACClass::enableInterrupts()':
C:\Users\Bruno Martinelle\Documents\Arduino\libraries\Audio\src/DAC.h:31:44: error: 'isrId' was not declared in this scope
  void enableInterrupts()  { NVIC_EnableIRQ(isrId); };
C:\Users\Bruno Martinelle\Documents\Arduino\libraries\Audio\src/DAC.h:31:49: error: 'NVIC_EnableIRQ' was not declared in this scope
C:\Users\Bruno Martinelle\Documents\Arduino\libraries\Audio\src/DAC.h: In member function 'void DACClass::disableInterrupts()':
C:\Users\Bruno Martinelle\Documents\Arduino\libraries\Audio\src/DAC.h:32:45: error: 'isrId' was not declared in this scope
  void disableInterrupts() { NVIC_DisableIRQ(isrId); };
C:\Users\Bruno Martinelle\Documents\Arduino\libraries\Audio\src/DAC.h:32:50: error: 'NVIC_DisableIRQ' was not declared in this scope
C:\Users\BRUNOM~1\AppData\Local\Temp\arduino_aeda8030121f38bce14ed58c8df04f59\SimpleAudioPlayer.ino: In function 'void loop()':
SimpleAudioPlayer:45: error: invalid conversion from 'short int*' to 'int16_t* {aka int*}' [-fpermissive]
In file included from C:\Users\BRUNOM~1\AppData\Local\Temp\arduino_aeda8030121f38bce14ed58c8df04f59\SimpleAudioPlayer.ino:3:0:
C:\Users\Bruno Martinelle\Documents\Arduino\libraries\Audio\src/Audio.h:21:7: error:   initializing argument 1 of 'void AudioClass::prepare(int16_t*, int, int)' [-fpermissive]
  void prepare(int16_t *buffer, int S, int volume);
SimpleAudioPlayer:47: error: call of overloaded 'write(short int [1000], const int&)' is ambiguous
C:\Users\BRUNOM~1\AppData\Local\Temp\arduino_aeda8030121f38bce14ed58c8df04f59\SimpleAudioPlayer.ino:47:26: note: candidates are:
C:\Users\Bruno Martinelle\Documents\Arduino\libraries\Audio\src/Audio.h:27:17: note: virtual size_t AudioClass::write(const uint16_t*, size_t) <near match>
  virtual size_t write(const uint16_t *data, size_t size) { return write(reinterpret_cast<const uint32_t*>(data), size/2) * 2; };
C:\Users\Bruno Martinelle\Documents\Arduino\libraries\Audio\src/Audio.h:27:17: note:   no known conversion for argument 1 from 'short int [1000]' to 'const uint16_t* {aka const unsigned int*}'
C:\Users\Bruno Martinelle\Documents\Arduino\libraries\Audio\src/Audio.h:28:17: note: virtual size_t AudioClass::write(const int16_t*, size_t) <near match>
  virtual size_t write(const int16_t *data, size_t size)  { return write(reinterpret_cast<const uint32_t*>(data), size/2) * 2; };
C:\Users\Bruno Martinelle\Documents\Arduino\libraries\Audio\src/Audio.h:28:17: note:   no known conversion for argument 1 from 'short int [1000]' to 'const int16_t* {aka const int*}'
exit status 1
  Este relatório deveria ter mais informações
  "Mostrar saída verbosa durante a compilação"
  habilitado em Arquivo > Preferências.
Alguém poderia me falar onde ta o problema? Se sim muito obrigado!
Porque é que está tudo rasurado e porque é que não usas as tags para código?
Até tem o simbolo # para marcar como código..
E que shield/chip estás a usar?
É que não é do atmega do Arduino que fazes stereo a 44.1Khz.
#2
É como o senso diz, tens de usar a tag code. É aquele hashtag (cardinal, #) que está por cima dos smiles.
Mas decifrando o teu texto o erro está aí e bem claro:
E outra vez o senso acertou na mouche: essa biblioteca não é para arduinos com ATMega(avr), mas com SAM(Cortex-M3) como o Arduino Due: https://www.arduino.cc/en/Main/ArduinoBoardDue
megamartinelle
Pois é, não tinha reparado que tinha ficado rasurado. Vou fazer o que disses
