Autor Tópico: [VENDA] Motor Drive Shield L293B (Arduino)  (Lida 11519 vezes)
Offline Carlcox89
« em: 14 de Julho de 2010, 13:26 »
Uploaded with ImageShack.us
This DFRduino motor drive shield, one type of Arduino motor drived shield,
allows an Arduino Duemilanove or Arduino Mega to drive 2 CHANNEL 7-12V DC
motors. It uses a L293B chip which deliveries the output current up to 1A.
This shield can be directly mounted onto standard Arduino Duemilanove or
Mega
boards.
The speed controler is achieved through the conventional PWM which can be
obtained from Arduino's PWM output Pins 5 and 6. The enable/disabled function
of the motor control is signalled by Arduino Digital Pins 7 and 8. The motor
shield uses PWM output Pins 6 and 9 and Digital Pings 7 and 8.
Features:
2-Channel 7-12V DC motor drive
Up to 1A current output each channel
Pins 5,6,7 and 8 are used to drive motors
Supports PWM speed control
Compatibility:
Arduino Diecimila
Arduino Duemilanove
Arduino Mega
Estado: Novo  (Apenas abri para verificar se estava a funcionar)
Preço: 17€ (Portes Incluídos)
« Última modificação: 14 de Julho de 2010, 13:28 por Carlcox89 »
