Autor Tópico: Sensor temperatura LM35DZ  (Lida 14077 vezes)
Offline joaopedrocmp
Re: Sensor temperatura LM35DZ
« Responder #15 em: 06 de Abril de 2012, 13:40 »
Boas outra vez,
Entretanto experimentei esta função , mas continua igual:
void printDouble( double val, byte precision){
  // prints val with number of decimal places determine by precision
  // precision is a number from 0 to 6 indicating the desired decimial places
  // example: printDouble( 3.1415, 2); // prints 3.14 (two decimal places)
  Serial.print (int(val));  //prints the int part
  if( precision > 0) {
    Serial.print("."); // print the decimal point
    unsigned long frac;
    unsigned long mult = 1;
    byte padding = precision -1;
    while(precision--)
mult *=10;
    if(val >= 0)
frac = (val - int(val)) * mult;
    else
frac = (int(val)- val ) * mult;
    unsigned long frac1 = frac;
    while( frac1 /= 10 )
padding--;
    while(  padding--)
Serial.print("0");
    Serial.print(frac,DEC) ;
