ora dá ora não dá ...
Started by paulojorgevl, 25 de August de 2012, 11:37
GnGz
Fornece o código , para ser mais facil de identificar o problema.
paulojorgevl
o erro que da é "programer out of sync"
Pedrock
Não adivinhamos onde está o problema sem o código...
GnGz
Manda o teu código, e no ide do arduino tens de verificar no menu se a board selecionada é a tua e a porta serial é a do arduino.
Para meter o teu código aqui no forum , no editor copias , clicas no botão # (inserir código) e depois colas.
paulojorgevl
Quote
  LiquidCrystal Library - Hello World
 Demonstrates the use a 16x2 LCD display.  The LiquidCrystal
 library works with all LCD displays that are compatible with the
 Hitachi HD44780 driver. There are many of them out there, and you
 can usually tell them by the 16-pin interface.
 This sketch prints "Hello World!" to the LCD
 and shows the time.
  The circuit:
 * LCD RS pin to digital pin 12
 * LCD Enable pin to digital pin 11
 * LCD D4 pin to digital pin 5
 * LCD D5 pin to digital pin 4
 * LCD D6 pin to digital pin 3
 * LCD D7 pin to digital pin 2
 * LCD R/W pin to ground
 * 10K resistor:
 * ends to +5V and ground
 * wiper to LCD VO pin (pin 3)
 Library originally added 18 Apr 2008
 by David A. Mellis
 library modified 5 Jul 2009
 by Limor Fried (http://www.ladyada.net)
 example added 9 Jul 2009
 by Tom Igoe
 modified 22 Nov 2010
 by Tom Igoe
 This example code is in the public domain.
 http://www.arduino.cc/en/Tutorial/LiquidCrystal
// include the library code:
#include <LiquidCrystal.h>
// initialize the library with the numbers of the interface pins
LiquidCrystal lcd(12, 11, 5, 4, 3, 2);
void setup() {
  // set up the LCD's number of columns and rows:
  lcd.begin(16, 2);
  // Print a message to the LCD.
  lcd.print("hello, world!");
void loop() {
  // set the cursor to column 0, line 1
  // (note: line 1 is the second row, since counting begins with 0):
  lcd.setCursor(0, 1);
  // print the number of seconds since reset:
  lcd.print(millis()/1000);
este é um dos muitos codigos que ja tentei copiar
e nunca chega ao fim o uploading
Pedrock
O problema não está no código. Consegui fazer o upload para o meu Arduino.
Vê se não tens nenhum problema com o arduino ou na IDE.
paulojorgevl
pois é esse problema.
o codigo esta ok mas não sei o que se passa com o arduino
existe alguma forma de fazer reset ao arduino?
GnGz
#22
Instalaste as drivers do mesmo?
Nos menus configuraste , para arduino duemilanove e com a porta serial do mesmo?
Sabes se consegues enviar o código para o arduino?
O circuito está bem ligado?
P.S: eu penso é que nunca conseguiste enviar o programa para o arduino... e está a executar código antigo.
Pedrock
O upload funciona com tudo desligado, por isso podes tentar desligar tudo para tentar fazer o upload.
paulojorgevl
tambem ja fiz o upload com tudo desligado e tambem não dá.
é isto que aparece depois de fazer upload
Pedrock
Tenta fazer upload do examplo Blink.
GnGz
#26
Responde as minhas perguntas.
paulojorgevl
Quote from: GnGz on 25 de August de 2012, 23:18
foi logo o que fiz foi instalar as drivers.
eu consguia enviar codigos no inicio pois ja fiz o teste com o led e a resistencia e tudo funcionou bem.
para ele receber os codigos é preciso estar ligado ao lcd ou basta ligar o cabo usb?
Pedrock
Faz o upload do Blink para ver se o Arduino ainda funciona correctamente.
GnGz
Basta o USB. Verifica se esta tudo bem configurado.
