Autor Tópico: Duvida sim900  (Lida 10426 vezes)
Offline joaopedrocmp
Duvida sim900
« em: 15 de Maio de 2016, 23:47 »
instalei uma biblioteca para o sim900, "gsm-gprs-gps-shield".
no caso seguinte recebo uma sms e é apresentado o numero e o conteúdo no serial monitor.
#include "SIM900.h"
#include <SoftwareSerial.h>
//If not used, is better to exclude the HTTP library,
//for RAM saving.
//If your sketch reboots itself proprably you have finished,
//your memory available.
//#include "inetGSM.h"
//If you want to use the Arduino functions to manage SMS, uncomment the lines below.
#include "sms.h"
SMSGSM sms;
//To change pins for Software Serial, use the two lines in GSM.cpp.
//GSM Shield for Arduino
//www.open-electronics.org
//this code is based on the example of Arduino Labs.
//Simple sketch to send and receive SMS.
int numdata;
boolean started=false;
char smsbuffer[160];
char n[20];
void setup()
     //Serial connection.
     Serial.begin(9600);
     Serial.println("GSM Shield testing.");
     //Start configuration of shield with baudrate.
     //For http uses is raccomanded to use 4800 or slower.
     if (gsm.begin(2400)) {
          Serial.println("\nstatus=READY");
          started=true;
     } else Serial.println("\nstatus=IDLE");
    // if(started) {
          //Enable this two lines if you want to send an SMS.
          //if (sms.SendSMS("3471234567", "Arduino SMS"))
          //Serial.println("\nSMS sent OK");
void loop()
     if(started) {
          //Read if there are messages on SIM card and print them.
        /**  deprecated method
        if(gsm.readSMS(smsbuffer, 160, n, 20)) {
               Serial.println(n);
               Serial.println(smsbuffer);
          //get 1st sms
          sms.GetSMS(1,n,20,smsbuffer,160);
          Serial.println(n);
          delay(3000);
o que necessito é fazer uma ação caso o numero e o conteúdo seja o que eu quero.
ja igualei o smsbuffer a uma string e envio o que esta nessa string e nao funciona.
opinioes?
Re: Duvida sim900
« Responder #1 em: 16 de Maio de 2016, 21:04 »
Como estavas a fazer a comparação das strings?
Re: Duvida sim900
« Responder #2 em: 16 de Maio de 2016, 22:15 »
Criei uma string   smstext {'a','d','u','i','n','o',,} depois fiz um , se smsfuffer == smstext,liga led
Re: Duvida sim900
« Responder #3 em: 17 de Maio de 2016, 08:28 »
http://lmgtfy.com/?q=string+compare+c# :)
