Palavras Cruzadas - Puzzle Nº1
Started by Hugu, 07 de September de 2017, 21:58
Deixo-vos o seguinte desafio (Puzzle nº1):
(versão printable para dl aqui)
Verticais:
1   Resistor color for "2"
2   Uses a transformer
3   Xilinx® spreadsheet
4   Assume lower capacitance
6   Pulse ________ Modulation
7   Tape & ________
10  _______ strap (engineer's bracelet)
13  Size or efficiency?
14  4.5V to 60V market
17  SPICE or Simplis file
19  V=IR
22  List of components
23  Integrated _______
24  Advanced engineering degree
26  AC loop analysis result
28  Limits inrush current
30  Australian rock band
32  VOUT/VIN
34  ______ Day (March 14)
37  Rechargeable battery chemistry
39  Transistor type
41  MAXM17504, for example
43  European Directive 2002/95/EC
46  Increases with switching speed
47  Pin for ?P
Horizontais:
5   _______ factor correction
8   EE-Sim's waveform viewer
9   It has a gate, source, and drain
11  Three parallel, horizontal lines
12  Demand on a power supply
13  A line fluctuation
15  Typical fSW unit
16  Not through-hole
18  Converts without switching
20  Six ______ shielding
21  Charge ____: capacitor-based converter
23  Inductor current never goes to zero
25  Step-up
27  Fastest simulator for switch-mode ICs
29  0% duty cycle
31  What Henries expresses
33  Edison's choice for the grid
35  Two   VOUTs
36  Powered by AC
38  Buck-boost topology
40  The perfect ripple plot
42  Make this short and wide
44  Volt/Ohm
45  Groundless
47  Digital power protocol
48  Heat _______
49  Measurement device
50  Power ______ (W/in^2)
Tentem participar respondendo a apenas um máximo de 3 palavras em cada post e evitando posts consecutivos, para assim permitir uma maior participação de mais users.
Quando se conseguir completar as palavras cruzadas, prometo uma surpresa para os participantes! :)
brunus
Já tenho 28 palavras preenchidas, aqui ficam as minhas 3 primeiras:
Nas verticais:
1=RED
6=WIDTH
22=BOM
brunus
Já posso dizer mais 3 correcto? :)
Ainda nas verticais:
10=ESD
23=CIRCUIT
34=PI
Esqueci-me referir que é um puzzle da Maxim Integrated e que há palavras que são de produtos da Maxim.
As minhas 3 palavras:
48: sink
37: lion
29: gnd
(actualizei o puzzle)
#5
Quote from: Hugu on 13 de September de 2017, 21:22
48: sink
37: lion
29: gnd
Essa 37 não me parece muito correta...
7-reel
31- inductance
43-rohs
Quote from: jm_araujo on 13 de September de 2017, 22:15
48: sink
37: lion
29: gnd
7-reel
31- inductance
43-rohs
Pois às tantas ..  :-[ mas encaixava tão bem :) ..também não estou a ver qual possa ser  ???
Deixo outras:
47: pmbus
49: scope
50: thermal
Quote from: Hugu on 15 de September de 2017, 00:17
48: sink
37: lion
29: gnd
Deixo outras:
47: pmbus
49: scope
50: thermal
Só encaixa por causa do erro, é Li-Ion (iões de Lítio) e não Lion (Leão). De 4 letras tens as de níquel (NiCd e NiMh)
Essa 50 também encaixa mas não parece correta. O que é "Power Thermal"?
#8
Quote from: jm_araujo on 15 de September de 2017, 07:46
oh diabo, nao acerto nenhuma! lol
qto ao power thermal foi tipo mais um tiro..porque o que encontro com essas medidas é o FSL e segundo a literatura é: FSL = combined surface loss factor at surface temperature (W/in2) ou entao é density ..Power Density ?
brunus
E mais três:
11= GROUND
16=SMD
30= ACDC
A ver se desta vez acerto todas  ::)
8: webscope
20: sided
23: ccm
Quote from: KammutierSpule on 18 de September de 2017, 21:59
45=FLOATING
só submetes uma?! ai que fraquinho que és!  ;D
46: noise
42: trace ?
32: efficiency
#13
Toma lá a minha contribuição para o teu prémio  ;D ;D
2 Isolated
13 Tradeoff
14 Industrial
19 Ohm's Law
26 Bode Plot
28 Soft start
37 NiMH
39 PNP
41 Module
13 Transient
15 MHz ou KHz
18 LDO
21 Pump
25 Boost
29 Off
33 DC
35 Dual
38 SEPIC
40 Flat
44 Amp
#14
só deviam ser 3 palavras de cada vez
