Autor Tópico: Arduino Software 0016  (Lida 12055 vezes)
Offline DanBar
    • iCAR Lusorobotica Blog
« em: 09 de Junho de 2009, 17:45 »
Nova versão do IDE
0016 - 2009.05.30
[documentation / examples]
* New communication examples (w/ corresponding Processing and Max/MSP code) by
  Tom Igoe.
[core / libraries]
* Adding support for the Arduino Pro and Pro Mini 3.3V / 8 MHz w/ ATmega328.
* Adding support for the LilyPad Arduino w/ ATmega328.
* Adding write(str) and write(buf, size) methods to Print, Serial, and the
  Ethernet library Client and Server classes.  This allows for more efficient
  (fewer packet) Ethernet communication.  (Thanks to mikalhart.)
* Improvements to the way the Ethernet library Client class connects and
  disconnects.  Should reduce or eliminate failed connections and long
  timeouts.  (Thanks to Bruce Luckcuck.)
* Optimizing the timer0 overflow interrupt handler (used for millis() and
  micros()).  Thanks to westfw and mikalhart.
* Fixing bug that limited the bit() macro to 15 bits.  Thanks to Paul Badger.
* Adding ARDUINO version constant (thanks to prodding from mikalhart).
[environment]
* Ordering the items in the Tools > Board menu.
* Adding "Copy as HTML" command to the Tools menu.
* Eliminating (maybe) the occasional "Couldn't determine program size" errors.
  Thanks to the Clever Monkey.
* Moving selection of Linux look-and-feel into the arduino script so it can
  be changed by users.  Thanks to Eberhard Fahle.
[tools]
* Adding automatic dependency generation to the Makefile.  (Lars Immisch)
http://arduino.cc/en/Main/Software
Antigo Nick do Forum: iCAR
Projectos iCAR
icar.lusorobotica.com
DB@G
Re:Arduino Software 0016
« Responder #1 em: 10 de Junho de 2009, 00:41 »
Obrigado pela info iCAR ;)
Vamos ver se é desta que já trás compatibilidade com o AERO do windows :P
Offline DanBar
« Responder #2 em: 10 de Junho de 2009, 00:44 »
Eu não tenho o AERO no meu XP, por isso já estou a trabalhar com ele. ;)
Projectos iCAR
DB@G
« Responder #3 em: 10 de Junho de 2009, 01:34 »
É compatível com o AERO do mac :P lol
Obrigado, não sabia que já tinha saido.
Os gajos do Arduino já faziam uma newsletter.
Offline Reonarudo
  • Nano Soldering Master
« Responder #4 em: 10 de Junho de 2009, 01:38 »
aero? desliga isso pah so te gasta recursos...
Leonardo Marques
« Responder #5 em: 10 de Junho de 2009, 01:43 »
depende do ponto de vista...neste momento o AERO está mais optimizado....Gasta recursos? sim, claro que gasta...
Mas só uso o PC que tem o aero para ir à net, programar e pouco mais...por isso nao me interessa muito e sempre fica mais bonito.
Alem disso tou a utilizar o windows 7 (beta tester) e digo-te que nao tem nada a ver com o Vista em consumos ;)
Offline joaoamaral
« Responder #6 em: 10 de Junho de 2009, 07:02 »
pois é no windows dá aquele erro (isso ja esta resolvido?) ainda so usei no linux
saquei o ide 016 apos ter sido alertado no twitter no dia em q saiu :)
continuando o rant dos sistemas operativos:
o hardware do mac é caro mas o osx é muito bom (uso mac mini)
o windows 7 do que vi ate agora esta muito bem (pelo que sei vai custar $50) e tem suporte para todo o hardware que se queira e os melhores jogos (Team Fortress 2 se alguem jogar podemos combinar)
* o linux com gnome quer ficar parecido com o osx é gratis cada vez mais é mais versatil (meu portatil)
o linux com kde quer ficar parecido com o windows e também é gratis
uso todas as opcoes excepto a ultima (kde) e a do asterisco é a minha preferida :)
