Autor Tópico: Acoustic Guitar - Record or play from piezo - IR Impulse Response  (Lida 12730 vezes)
Offline blabla
How to record or play live an Acoustic Guitar from a piezo pickup - Impulse Response
The sound from the piezo isn't a real replica of the sound of the instrument that you listen directly from the instrument. So you will need to record some WAV files from it and from a condenser microphone simultaneouslly. Then calculate with a small program the impulse response (IR) that will transform the linear "distorted" piezo output into the sound that the instrument acustically produces, and that you can listen to. The IR is then applyed to the guitar recording track, or you can use a IR speaker simulator like Two Notes Torpedo C.A.B. M+ Speaker Sim, this will enable you to apply it in real time to your sound and make the transformation (convolution of the IR). The ToneDexter from Audio Sprockets does this in a one stop solution. But you have the option to choose between the three possibilities ... apply the IR on the computer, realtime on a IR speaker simulator. or use the ToneDexter that does all the process. But read on the technical details about the subject, because they are really interesting.
Acoustic IR
http://acousticir.free.fr/
Jon Fields open source algorithm
http://acousticir.free.fr/spip.php?article136
Doug Young IR comparisson
https://www.acousticguitarforum.com/forums/showpost.php?p=6278203&postcount=12
For realtime processing you can load the IR - Impulse Response into the Two Notes Torpedo C.A.B. M+ Speaker Sim.
James May Interview with Aaron Short Music
https://www.youtube.com/playlist?list=PLLjzz35wt_751gL6LJIs_1KPZ2WcCSM0t
ToneDexter - Audio Sprockets
https://audiosprockets.com/
João
