Autor Tópico: High Voltage USB-Isolator - Raspberry Pico USB-Serial at high speeds!  (Lida 8276 vezes)
Offline blabla
Hello,
I am very pleased with Raspberry Pico USB-Serial connection currently I’m getting 2 Mbits/s  in GTKTerm. The max speed of the program, maybe the connection can go even higher.
But even more impressive is that I can get 2 Mbit’s of USB-Serial from the Raspberry Pico, with my little program in the following conditions:
Raspberry Pi Pico in Rust Proj Template with RTIC USB-Serial and UF2
https://github.com/joaocarvalhoopen/Raspberry_Pi_Pico_in_Rust__Proj_Template_with_RTIC_USB-Serial_UF2
First I have a 2 meters USB-A to USB-B type connector with a USB 2.0 rated cable, following that  I have a USB-ISO High Voltage Isolator that gives 1000V Isolation on USB and that is a cheap but I thing good product. It uses the Analog Devices IC’s for USB Isolation:
USB-ISO - OLIMEX
https://www.olimex.com/Products/USB-Modules/USB-ISO/
In the manual, it says that the cable should be 1.8 meters long at both ends.
Then from the isolator I have put a USB 3.0 3 meters male-female cable and then it goes into a 1 meter cable into a USB-Hub with Power Supply and then it goes with a 1 meter cable into the Pico that is also giving power to other pico.
So the chain is:
PC Linux -> 2 meters USB 2.0 -> USB-ISO 1KV Isolator  no external power supply -> 3 meters of USB 3.0 -> 1 meter of cable USB Hub -> USB 1 meter -> Raspberry Pico
This at 2 Mbits/s serial terminal on GTKTerm, verified with the Pico internal API:
let data_rate = serial.line_coding().data_rate();
Best regards,
João
« Última modificação: 25 de Fevereiro de 2022, 22:07 por blabla »
