Projecto Freza CNC - Arduino
Started by c3dr1c, 24 de January de 2012, 19:50
c3dr1c
Os de efeito hall nao tenho muito interesse. Estava a pensar em algo com fios.
Tenho de ir ver esse max, mas assinar papeis as vezes nao é bom sinal :P
Entao nao da para medir directo com arduino, devido as correntes serem grandes, certo?
Quote from: CBX on 25 de April de 2012, 21:17
meio manhosos como?
Manhoso assim:
Quote
Maxim Integrated Products
4401 S. Beltwood Parkway
Dallas, TX 75244
Dear Customer,
The Maxim Integrated Products, Inc. ("Maxim") parts requested by or purchased from your company are subject to U.S. export regulations.  As such, Maxim must obtain certain information about you or your company's end-use in order to comply with various U.S. trade regulations.  For example, the U.S. Export Administration Regulations (15 CFR Parts 730 to 774) may require an export license by the U.S. government for military end-uses or end-users.
In order for Maxim to make a proper license determination and complete required export documentation, it is essential that your company provide a signed Statement of Assurance (page two of this letter) regarding the end-use and end-users of the Maxim products.   The end-user is defined as the ultimate consignee who will be using the product.   The end-use is defined as the final product that the Maxim product will be integrated into (e.g. automobile, radar system, kitchen appliances, etc.).   Maxim will keep the Statement of Assurance on File for two (2) years.  If the end-user or end-use has changed and/or the 2 years has expired, a new Statement of Assurance will be required prior to the delivery of the product.
Once the statement of assurance is complete, please return the Statement of Assurance via email to Compliance@Maxim-ic.com  or fax to 1- 972-778-6428.   If you need assistance or have questions regarding the Statement of Assurance request please contact our office by sending an email to Compliance@Maxim-ic.com  with your contact information.  Someone from the Trade Compliance Office will respond to your request as soon as possible.
Best Regards,
Maxim Global Trade Compliance Department
STATEMENT OF ASSURANCE – Civil End Use
We acknowledge the export/re-export of commodities, technical data, and/or software ("Controlled Items") that we have purchased, or will purchase, from Maxim Integrated Products, Inc. ("Maxim"), are subject to the U.S. export control laws and regulations, including the Export Administration Regulations ("EAR") issued by the U.S. Department of Commerce ("DoC"), and the Embargo and Sanction Regulations administered by the U.S. Department of Treasury, Office of Foreign Assets Controls ("OFAC"), among other rules and regulations.  We agree and undertake to comply with all applicable U.S. export control laws and regulations.  In particular:
1.   We certify that we will not directly or indirectly export, re-export, transmit, or cause to be exported, re-exported or transmitted, any Controlled Items to any country, individual, corporation, organization, or entity to which such export, re-export, or transmission is restricted or prohibited.
2.   We certify that we will use the Controlled Items for civil end-uses only.
      Ultimate End Use Application:___________________________________________________________________
3.   We certify that we will not use Controlled Items in relation to military end uses as defined in the EAR for nuclear, biological or chemical weapons, or the missile systems that deliver them; for the design, development, production, testing, stockpiling or use of any weapons of mass destruction; or for any other use that the U.S. government prohibits.
4.   We acknowledge that it is our responsibility to obtain any required license to export/re-export or to transmit information regarding any Controlled Items as may be required under any export control laws or regulations.  We will not export, re-export, or transmit any Controlled Items except in accordance with the provisions of the EAR; such provision prohibit export or reexport to an embargoed country, transfer to persons or entities ineligible to receive U.S. products, or used in a military or proliferation related activity without prior authorization of Bureau of Industry and Security (BIS), and/or terms of a license issued by an applicable U.S. government authority.
This Certification shall survive the term and termination of the relationship between Maxim the Purchaser and Consignee.
STATEMENT OF ULTIMATE CONSIGNEE AND PURCHASER We certify by signature that all of the facts contained in this statement are true and correct to the best of our knowledge and will apply to the disposition of products purchased from Maxim.  We shall promptly notify the U.S. Exporter, to disclose any change of facts or intentions set forth in this statement which occurs after the statement has been prepared and forwarded.
We acknowledge that the making of any false statements or concealment of any material fact in connection with this statement may result in denial, in whole or in part of participation in U.S. exports and re-exports.
c3dr1c
Tanta preocupação com um simples integrado :P as vezes tem que ser
E sem ser sample, alguem recomenda algum sensor de corrente que conhece ou que ja tenha experimentado?
c3dr1c
#138
É verdade, montei um regulador de tensao, mas tenho uma duvida. O multivoltas tem de aguentar com a corrente que vai ser consumida certo? Como sao os motores de passo pode ir ate 3A, portanto aquele nao funciona, certo?
O regulador é um LM350T.
Ja tenho todos os "rolamentos" lineares e chumaceiras que preciso, ja faltou mais :D
Para suportar os "rolamentos" vou usar braçadeiras
Abraços
patinhofeio
Quote from: PDI on 25 de April de 2012, 20:00
Quote from: patinhofeio on 25 de April de 2012, 19:39
Boas.
Podes usar um sensor de efeito hall. É o que algumas pinças amperimétricas usam para medir a corrente sem interceptarem o condutor
Eu pensava que utilizavam um transformador.
Boas.
Há pinças e pinças. As que medem corrente AC e DC por meio da pinça usam sensores de hall. As pinças que usam transformador apenas pedem por pinça correntes AC, e a DC é medida com as pontas de prova(os que medem)
PDI
Quote from: patinhofeio on 26 de April de 2012, 00:06
Boas.
Boas.
Esclerecido, obrigado.
c3dr1c
Alguem tem ideia onde posso encontrar daquele tipo de abraçadeiras que postei acima? Sem ser no Brasil :P que ha as carradas...
PDI
já tentas-te casas de material de canalização?
c3dr1c
ainda nao... boa ideia thanks :D
PDI
Estamos aqui para isso, ajudar uns aos outros
c3dr1c
Estou com uma terrivel duvida que me está assombrar :P
Eu tenho chumaceiras de 10mm para os fusos. Estava a pensar usar fusos M12, mas quando peguei neles, txi acho um exagero. M10 ficava bem e era mais leve. Mas de qualquer maneira tenho de usar M12, pois como as chumaceiras sao de 10mm e como preciso de desgastar a rosca de modo a ter uma superficie lisa em contacto com a chumaceira, nao tenho outra hipotese.
So me esqueci de medir uma coisa. Se com um fuso M12, desgastando a rosca, para ter essa superficie lisa com 10mm de diametro, nao fico com rosca ainda. Se a altura da rosca nao excesse 1mm.
Alguem me consegue informar sobre isto? Porque se nao tenho de usar fusos M14  :o :o
Eu estive a ver qual o diametro do furo, a efectuar com o berbequim para depois entao construir a rosca e é de 10,2mm. Será que este diametro corresponde ao diametro do parafuso/fuso, sem rosca?
Abraços
Não precisas de ter uma face perfeitamente plana, por exemplo na CNC do mauro onde os varões roscados passam nas chumaceiras ainda notas alguns traços da rosca do varão, mas isso não influencia.
PDI
Não tens ai um parafuso M10, medes e já tens uma medida mais aproximada, ou alargas uma porca e vez.
c3dr1c
Mas com chumaceiras feitas com polimeros, deve haver um grande desgaste. Nao achas?
Se eu nao tivesse so uma regua, mas sim um paquimetro, eu media :P
Um dia ver se compro um...
Tenho de experimentar a medir o diametro com o perimetro de um fio...
Tambem compras um paquimetro no ebay por 10€ já com portes, nem é caro.
